 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : lpg montajı</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : lpg montajı]]></description>
  <pubDate>Fri, 01 May 2026 20:22:44 +0000</pubDate>
  <lastBuildDate>Mon, 25 Jul 2011 09:24:25 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=16616</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[lpg montajı : Multi fast, fast ve safe fast...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256596&amp;title=lpg-montaji#256596</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Temmuz&nbsp;2011 Saat 09:24<br /><br />Multi fast, fast ve safe fast sıralamasıyla kıtler pıyasaya cıkmıstır. Tesisatları farklıdır. Sadece ecu degısımıyle yenı kıte donusturemezsınız...]]>
   </description>
   <pubDate>Mon, 25 Jul 2011 09:24:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256596&amp;title=lpg-montaji#256596</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı :   riva70 Yazd&#305;:lpg sisteminin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256506&amp;title=lpg-montaji#256506</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4734">metin</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 23:25<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: riva70" alt="Orjinalini yazan: riva70" style="vertical-align: text-bottom;" /> <strong>riva70 Yazdı:</strong><br /><br />lpg sisteminin beynini degiştirsek yeterli olurmu?<DIV>ama arkadasımın megane 2 var atiker fast sistemi var sorunsuz kullanıyor arıza ısıgıda yakmıyor bildiğim kadarıyla o daha eski bir sisitem degilmi?</DIV></td></tr></table><DIV>&nbsp;</DIV><DIV>her motor aynı değil bence. </DIV>]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 23:25:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256506&amp;title=lpg-montaji#256506</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı :   Arac cok yak&#305;yor ve ar&#305;za...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256476&amp;title=lpg-montaji#256476</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3054">riva70</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 22:44<br /><br />Arac cok yakıyor ve arıza ısıgı yanıyor bulundugum yerde sordugumda da bu imkansız lamba yanar diyor yakıtı da ayarlıyor ayarlıyor düşmüyor.]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 22:44:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256476&amp;title=lpg-montaji#256476</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı : sistem de bir hata varsa ve ya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256473&amp;title=lpg-montaji#256473</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5639">mimitt</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 22:40<br /><br />sistem de bir hata varsa ve ya bir hata olduğunu düşünüyorsanız öncelikle sizin sorularınıza ve isteklerine cevap verecek bir yer bulmanız lazım,öyle hatalı montajı yapılmış sistemler gördüm ki tamamen sökülüp sıfırdan montajlanması gerekti,hatta bir aracın manifoldunu da değiştirmek zorunda kaldık.]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 22:40:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256473&amp;title=lpg-montaji#256473</guid>
  </item> 
  <item>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256451&amp;title=lpg-montaji#256451</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 22:15<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: riva70" alt="Orjinalini yazan: riva70" style="vertical-align: text-bottom;" /> <strong>riva70 Yazdı:</strong><br /><br />lpg sisteminin beynini degiştirsek yeterli olurmu?<DIV>ama arkadasımın megane 2 var atiker fast sistemi var sorunsuz kullanıyor arıza ısıgıda yakmıyor bildiğim kadarıyla o daha eski bir sisitem degilmi?</DIV></td></tr></table><BR>bence sistemi bi eldengeçirin bana cecoli abim demişti bende fast kit var demişti önemli olan usta demişti hem fastın programlanması kolay demişti.o bana maslakta&nbsp;bır yer&nbsp;önermişti. ben bi ara lpg yi düşündüm.adamlar v12 motora lpg takmış sanırsam 2 tane 6 silindir kit . ve bu yeri çok met ediyorlar.<span style="font-size:10px"><br /><br />Düzenleyen CeCoLi - 25&nbsp;Temmuz&nbsp;2011 Saat 09:20</span>]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 22:15:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256451&amp;title=lpg-montaji#256451</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı :   lpg sisteminin beynini degi&#351;tirsek...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256444&amp;title=lpg-montaji#256444</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3054">riva70</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 21:26<br /><br />lpg sisteminin beynini degiştirsek yeterli olurmu?<div>ama arkadasımın megane 2 var atiker fast sistemi var sorunsuz kullanıyor arıza ısıgıda yakmıyor bildiğim kadarıyla o daha eski bir sisitem degilmi?</div>]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 21:26:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256444&amp;title=lpg-montaji#256444</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı : evet bencede aracla uyumlu olan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256442&amp;title=lpg-montaji#256442</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 21:22<br /><br />evet bencede aracla uyumlu olan en yenı sıstem ve cok iyi bir montaj bunlar gereklı suanda en iyi teknolojo obd teknolojısı her markada obd olanı kullanın arac anlık yakıt tuketımını kendı ayarlıyor bende bunları metin ve cecoliden ogrendım salı gunu bende atıker safe fast obd2 taktırıyorum :)))]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 21:22:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256442&amp;title=lpg-montaji#256442</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı : riva70. bildi&#287;im kadar&#305; ile safe...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256439&amp;title=lpg-montaji#256439</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4734">metin</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 21:18<br /><br />riva70. bildiğim kadarı ile safe fastlar güzel çalışıyor ama multifast eski olduğu için nasıl olur bilmiyorum. Multifastın çalışma sistemini özelliklerini vs araştırmak araç ile karışlaştırmak lazım ozaman uyum konusu daha iyi anlaşılır.]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 21:18:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256439&amp;title=lpg-montaji#256439</guid>
  </item> 
  <item>
   <title><![CDATA[lpg montajı :   merhaba arac&#305;m&#305;n benden &#246;nceki...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256423&amp;title=lpg-montaji#256423</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3054">riva70</a><br /><strong>Konu:</strong> 16616<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Temmuz&nbsp;2011 Saat 20:23<br /><br />merhaba aracımın benden önceki sahibi atiker marka lpg taktırmıs.<div>tam performans için iyi montaj yapan yere&nbsp;yaptırınız deniyor bende katılıyorum ama yapılmış bir kere.</div><div>bu konularda fazla bilgim yok ancak bu montajı kusursuz hala getirmenin bir caresi yokmu yani tekrar montaj, tamir vs. ?</div><div>tesekkurler.</div>]]>
   </description>
   <pubDate>Sun, 24 Jul 2011 20:23:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=16616&amp;PID=256423&amp;title=lpg-montaji#256423</guid>
  </item> 
 </channel>
</rss>
