 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : ilk kalkışta titreme</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : ilk kalkışta titreme]]></description>
  <pubDate>Mon, 04 May 2026 16:52:51 +0000</pubDate>
  <lastBuildDate>Fri, 24 Jun 2011 17:00:27 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=15872</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[ilk kalkışta titreme : akl&#305;ma gelmedi de&#287;il ama ara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240346&amp;title=ilk-kalkista-titreme#240346</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6521">DRIVER34</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 17:00<br /><br />aklıma gelmedi değil ama araç soğukken yapması volant seçeneğini eledi gibi yada ben kabul etmek istemiyorum sanırım :)&nbsp;]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 17:00:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240346&amp;title=ilk-kalkista-titreme#240346</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme : ben&#305;m b&#305;ld&#305;g&#305;m kalk&#305;sta t&#305;tremey&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240340&amp;title=ilk-kalkista-titreme#240340</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5503">axi206</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:53<br /><br />benım bıldıgım kalkısta tıtremeyı volantta yapar.]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:53:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240340&amp;title=ilk-kalkista-titreme#240340</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme : ak&#351;am bir bakt&#305;ray&#305;m sanayide.....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240318&amp;title=ilk-kalkista-titreme#240318</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6521">DRIVER34</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:24<br /><br />akşam bir baktırayım sanayide..&nbsp;]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:24:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240318&amp;title=ilk-kalkista-titreme#240318</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme : ilk ba&#351;ta benzine yordum fullden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240317&amp;title=ilk-kalkista-titreme#240317</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6521">DRIVER34</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:23<br /><br />ilk başta benzine yordum fullden alınıyordu benzin acaba gaz kelebeğini temizleteyimmi dedim sonra zaman zaman vites geçişlerinde sıkıntı olunca bilhassa 1 den 2 ye debriaja yordum açıkçası..&nbsp;]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:23:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240317&amp;title=ilk-kalkista-titreme#240317</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme : lifte kald&#305;rt&#305;p bir motor ku&#305;laklar&#305;na...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240315&amp;title=ilk-kalkista-titreme#240315</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5509">forewer_fb</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:23<br /><br /><P>lifte kaldırtıp bir motor kuılaklarına baktır derim, alt yada üst bazen kauçuk kısım kopmuş olabiliyor çatlıyabiliyor.</P>]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:23:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240315&amp;title=ilk-kalkista-titreme#240315</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme : zaman zaman ama ayk&#305;r&#305; de&#287;il normal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240311&amp;title=ilk-kalkista-titreme#240311</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6521">DRIVER34</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:21<br /><br />zaman zaman ama aykırı değil normal olara düşük devir kullandığında oluşan titreme büyük bir vuruntu olmuyor yüksek devirli (5-6) kullaanımda da sıkıntı olmadı açıkçası&nbsp;]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:21:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240311&amp;title=ilk-kalkista-titreme#240311</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme : buna benzer bir sorun bendede...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240305&amp;title=ilk-kalkista-titreme#240305</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5509">forewer_fb</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:17<br /><br />buna benzer bir sorun bendede&nbsp; vardı motor kulağından kaynaklanıyormuş.&nbsp; yüksek vites düşük devirde de aynı sıkıntı oluyor mu?]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:17:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240305&amp;title=ilk-kalkista-titreme#240305</guid>
  </item>
  <item>
   <title><![CDATA[ilk kalkışta titreme :  &#246;ncelikle herkeze selamarac&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240300&amp;title=ilk-kalkista-titreme#240300</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6521">DRIVER34</a><br /><strong>Konu:</strong> 15872<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2011 Saat 16:12<br /><br />öncelikle herkeze selam&nbsp;<div>aracım 2005 model307 &nbsp;1.4 xr &nbsp;16V araç sabahları yani motor soğukken kalkışta titreme yapıyor sanki motor kulaklarından kaynaklanıyormuş gibi tahminimce debriajda sıkıntı var vitese geçişlerde de sorun yaşıyorum bilhassa geride sizce neden kaynaklanır.. Bu arada aracı &nbsp; çok düşük devirde kaldırırsam sıkıntı olmuyor .. &nbsp;&nbsp;</div><span style="font-size:10px"><br /><br />Düzenleyen AlbaYDemircaN - 24&nbsp;Haziran&nbsp;2011 Saat 16:18</span>]]>
   </description>
   <pubDate>Fri, 24 Jun 2011 16:12:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15872&amp;PID=240300&amp;title=ilk-kalkista-titreme#240300</guid>
  </item>
 </channel>
</rss>
