 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : oksijen sensörü 307</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : oksijen sensörü 307]]></description>
  <pubDate>Mon, 04 May 2026 06:33:15 +0000</pubDate>
  <lastBuildDate>Sat, 04 Jun 2011 09:38:33 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=15295</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[oksijen sensörü 307 : tek adet evet ikisi 300-350 tl...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=228360&amp;title=oksijen-sensoru-307#228360</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4734">metin</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2011 Saat 09:38<br /><br /><P>tek adet evet ikisi 300-350 tl ye geliyor. </P><DIV>diğer tıkanma konusunda da <EM><strong>kankam_743'</strong> e katılıyorum.</EM></DIV><DIV>&nbsp;</DIV>]]>
   </description>
   <pubDate>Sat, 04 Jun 2011 09:38:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=228360&amp;title=oksijen-sensoru-307#228360</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 :   metin Yazd&#305;:  kankam_743 Yazd&#305;:ewt...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=228309&amp;title=oksijen-sensoru-307#228309</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4932">ose</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2011 Saat 02:16<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: metin" alt="Orjinalini yazan: metin" style="vertical-align: text-bottom;" /> <strong>metin Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: kankam_743" alt="Orjinalini yazan: kankam_743" style="vertical-align: text-bottom;" /> <strong>kankam_743 Yazdı:</strong><br /><br />ewt metin arkadaşımızın dediği gibi oksijen sensörü iki tanedir katalitiğin girişinde ve çıkışında. Yanması ise ewet doğal olarak genelde onlar motor arıza ışığını yakar yakıyor die onların arızalı olduğunu göstermez. şayet arızalı olsa aracın çalışmaz istop eder. Yakma nedeni lpg den fakir karışım yada bol oksijen uyarısından dolayı arıza ışığını yakar. LPg ayarların düzgün yaptır ve ışığı söndürtürsen daha yakmaz. BAzen kötü yakıttan da yakabiliyor ve gidip södürene kadar yanar yanılmıyosam. bişey daha iki sensör toplam 500tl yi geçiyor daha değişmeyi düşünmezsin herhalde:))</td></tr></table> <DIV>&nbsp;</DIV><DIV>orjinali bosch' dur. 250-280 tl dir ama bocsh bayinden alırsan 170 tl falan. Arızalı olduğunu sanmıyorum onun yerine depoya temizleyici atmalısın ayrıca pislik olsa motoru değil benzin pompasını yakar.</DIV></td></tr></table> ewt tek adet dimi? YAkıtın kötü olması derken kimyasal oranı bozuk benzin veya mazot anlamında kullandım. Yoksa benzinde pislik olsa motora ulaşmadan filtrelere takılır kalır. Pompanın çekiş hortumunun ucunda pompaya zarar verecek kalıntılara karşı ayrıca filtre görevi yapan delikli kumaş tel veya daha sert plastikten yapılma ızgara var. Orası da tıkanırsa dolayısıyla sorunlar oluşabilir.&nbsp;&nbsp;]]>
   </description>
   <pubDate>Sat, 04 Jun 2011 02:16:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=228309&amp;title=oksijen-sensoru-307#228309</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 :   kankam_743 Yazd&#305;:ewt metin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227671&amp;title=oksijen-sensoru-307#227671</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4734">metin</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2011 Saat 08:38<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: kankam_743" alt="Orjinalini yazan: kankam_743" style="vertical-align: text-bottom;" /> <strong>kankam_743 Yazdı:</strong><br /><br />ewt metin arkadaşımızın dediği gibi oksijen sensörü iki tanedir katalitiğin girişinde ve çıkışında. Yanması ise ewet doğal olarak genelde onlar motor arıza ışığını yakar yakıyor die onların arızalı olduğunu göstermez. şayet arızalı olsa aracın çalışmaz istop eder. Yakma nedeni lpg den fakir karışım yada bol oksijen uyarısından dolayı arıza ışığını yakar. LPg ayarların düzgün yaptır ve ışığı söndürtürsen daha yakmaz. BAzen kötü yakıttan da yakabiliyor ve gidip södürene kadar yanar yanılmıyosam. bişey daha iki sensör toplam 500tl yi geçiyor daha değişmeyi düşünmezsin herhalde:))</td></tr></table><DIV>&nbsp;</DIV><DIV>orjinali bosch' dur. 250-280 tl dir ama bocsh bayinden alırsan 170 tl falan. Arızalı olduğunu sanmıyorum onun yerine depoya temizleyici atmalısın ayrıca pislik olsa motoru değil benzin pompasını yakar.</DIV>]]>
   </description>
   <pubDate>Fri, 03 Jun 2011 08:38:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227671&amp;title=oksijen-sensoru-307#227671</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 : ewt metin arkada&#351;&#305;m&#305;z&#305;n dedi&#287;i...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227620&amp;title=oksijen-sensoru-307#227620</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4932">ose</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2011 Saat 02:03<br /><br />ewt metin arkadaşımızın dediği gibi oksijen sensörü iki tanedir katalitiğin girişinde ve çıkışında. Yanması ise ewet doğal olarak genelde onlar motor arıza ışığını yakar yakıyor die onların arızalı olduğunu göstermez. şayet arızalı olsa aracın çalışmaz istop eder. Yakma nedeni lpg den fakir karışım yada bol oksijen uyarısından dolayı arıza ışığını yakar. LPg ayarların düzgün yaptır ve ışığı söndürtürsen daha yakmaz. BAzen kötü yakıttan da yakabiliyor ve gidip södürene kadar yanar yanılmıyosam. bişey daha iki sensör toplam 500tl yi geçiyor daha değişmeyi düşünmezsin herhalde:))<span style="font-size:10px"><br /><br />Düzenleyen kankam_743 - 03&nbsp;Haziran&nbsp;2011 Saat 02:10</span>]]>
   </description>
   <pubDate>Fri, 03 Jun 2011 02:03:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227620&amp;title=oksijen-sensoru-307#227620</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 :   ozi033 Yazd&#305;:ara&#231; lpg li 2003...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227501&amp;title=oksijen-sensoru-307#227501</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4734">metin</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2011 Saat 00:04<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ozi033" alt="Orjinalini yazan: ozi033" style="vertical-align: text-bottom;" /> <strong>ozi033 Yazdı:</strong><br /><br />araç lpg li 2003 model xt.yakıt şehir içinde 280 kr yani 100 km de 12 lt gaz yakıyor gibi bişy.uzun yolda 20 kuruş ortalama.bujiler filtreler değişmişti.4000 km oldu değişeli.çekişinden yakıtından &nbsp;biraz şikayetçiyim.sensörün etkileyebileceğini düşünüyorum .birde ışık yanınca ondan olabileceğini düşünüyorum..lpg ayarındanda olabilir.ayar yaptırmıştım değişmedi.ışık sönmedi</td></tr></table><DIV>&nbsp;</DIV><DIV>araç otomatik mi? </DIV><DIV>&nbsp;</DIV><DIV>lpg sisteminin markası modeli nedir</DIV><DIV>&nbsp;</DIV><DIV>profil bölümünde imza kısmına yazarmısın görmeyenler her dafasında sormaz hem. </DIV><DIV>&nbsp;</DIV><DIV>bu tip sıkıntılar genelde ayardan oluyor zengin yada fakir karışım sonucu lamba yanıyor. iyi ayarlattığına eminmisin</DIV>]]>
   </description>
   <pubDate>Fri, 03 Jun 2011 00:04:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227501&amp;title=oksijen-sensoru-307#227501</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 :   ara&#231; lpg li 2003 model xt.yak&#305;t...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227473&amp;title=oksijen-sensoru-307#227473</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4378">ozi033</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Haziran&nbsp;2011 Saat 23:11<br /><br />araç lpg li 2003 model xt.yakıt şehir içinde 280 kr yani 100 km de 12 lt gaz yakıyor gibi bişy.uzun yolda 20 kuruş ortalama.bujiler filtreler değişmişti.4000 km oldu değişeli.çekişinden yakıtından &nbsp;biraz şikayetçiyim.sensörün etkileyebileceğini düşünüyorum .birde ışık yanınca ondan olabileceğini düşünüyorum..lpg ayarındanda olabilir.ayar yaptırmıştım değişmedi.ışık sönmedi]]>
   </description>
   <pubDate>Thu, 02 Jun 2011 23:11:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227473&amp;title=oksijen-sensoru-307#227473</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 : ozi033 307 lerde iki adet vard&#305;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227470&amp;title=oksijen-sensoru-307#227470</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4734">metin</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Haziran&nbsp;2011 Saat 23:06<br /><br />ozi033 307 lerde iki adet vardır biri üst oksijen sensörü diğeri alt oksijen sönsörüdür diğeri altta katalizöerün oradadır. <DIV>&nbsp;</DIV><DIV>öncelikle imza bölümünde aracının bilgilerini paylaşırsan daha iyi yardımcı olunur çünki 307 ler tek çeşit değil. </DIV><DIV>&nbsp;</DIV><DIV>arıza ışığının bir çok sebebi olabilir sadece sensör ile halledilemez yani. sen aracının özelliklerini donanımını yakıtını ayrıntılı yazarsan daha iyi yardımcı olur arkadaşlar.</DIV>]]>
   </description>
   <pubDate>Thu, 02 Jun 2011 23:06:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227470&amp;title=oksijen-sensoru-307#227470</guid>
  </item>
  <item>
   <title><![CDATA[oksijen sensörü 307 :   307 lerdeki oksjen sens&#246;r&#252;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227466&amp;title=oksijen-sensoru-307#227466</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4378">ozi033</a><br /><strong>Konu:</strong> 15295<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Haziran&nbsp;2011 Saat 22:58<br /><br />307 lerdeki oksjen sensörü motordaki egzoz manifoldunun üzeindeki parça değil mi?ve bundan 1 adet var sanıırsam.bu parçayı değiştirisek.motor ikaz ışığı söner mi acaba.artık can sıkıcı olmaya başladı.öncelikle depoyu 2 sefer baya bi dolduracam.(baya bi zor olacak:))çünkü depo dibindeki pislikler falan tıkıyordur yada az geliyordu ondan oluyodur deniyor ama ben sanmıyorum.eğer düzelmezse sonunda da en son oksijen sensörü değiştircm.birde bu yeni parça takılınca ayar falan istemiyor dimi.makineye bağlamak falan yok yani.teşşekürler..]]>
   </description>
   <pubDate>Thu, 02 Jun 2011 22:58:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=15295&amp;PID=227466&amp;title=oksijen-sensoru-307#227466</guid>
  </item>
 </channel>
</rss>
