 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 Lpg bilgi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 Lpg bilgi]]></description>
  <pubDate>Sat, 02 May 2026 06:15:19 +0000</pubDate>
  <lastBuildDate>Fri, 20 May 2011 16:58:46 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=14893</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 Lpg bilgi :    CeCoLi Yazd&#305;:r&#305;ca eder&#305;m....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=220466&amp;title=206-lpg-bilgi#220466</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6196">lomax</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2011 Saat 16:58<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: CeCoLi" alt="Orjinalini yazan: CeCoLi" style="vertical-align: text-bottom;" /> <strong>CeCoLi Yazdı:</strong><br /><br />rıca ederım. makıne 1.4 mu 1.6 mı?</td></tr></table><br><br>Geç oldu ama malum sakatlık yaşadık :) araç 1.4 <br>]]>
   </description>
   <pubDate>Fri, 20 May 2011 16:58:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=220466&amp;title=206-lpg-bilgi#220466</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi :   trigger Yazd&#305;:bu arada cecoli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219616&amp;title=206-lpg-bilgi#219616</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2011 Saat 11:05<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: trigger" alt="Orjinalini yazan: trigger" style="vertical-align: text-bottom;" /> <strong>trigger Yazdı:</strong><br /><br />bu arada cecoli arkadaş bu işlerden anlıyor, ben sadece kullanıp memnun kaldığım için önerebiliyorum, her türlü yardımcı olurum işleri kararlaştırdığında</td></tr></table> <DIV></DIV>&nbsp;<DIV>estagfurullah ne demek. sen taktırıpta memnun kaldıgın yerı tavsıye edeceksın tabıkı bu cok dogal bırsey.</DIV>]]>
   </description>
   <pubDate>Thu, 19 May 2011 11:05:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219616&amp;title=206-lpg-bilgi#219616</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi :    CeCoLi Yazd&#305;:fs otogaz&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219581&amp;title=206-lpg-bilgi#219581</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2011 Saat 01:56<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: CeCoLi" alt="Orjinalini yazan: CeCoLi" style="vertical-align: text-bottom;" /> <strong>CeCoLi Yazdı:</strong><br /><br /><p>fs otogazın acılımı,&nbsp;Faruk Sevgılıden gelıyor dıye hatırlıyorum. ya oranın sahıbı yada yetkılısı</p><div></div><div></div>lpg sıstemı konusunda atıker safe fast, lovato, zavolı, brc vs kullanabılırsın. kıtıne gore lambda baglantılarını yaptırırsan cokta guzel calısır tereyagı gıbı olur. hepsı senın motorun ıle duzgun calısacak kıtler. fakat montaj ve ayardan dolayı olusabılecek sorunlar usta faktorunu ortaya cıkarıyor. <div>&nbsp;</div><div>lpg duzgun montajlanırsa cekıste vs hıcbır sorun olmaz. bunu kendı aracımla&nbsp;otoyoldada ıspat ettım yanı... ısteyen vıdeoyu ızler&nbsp;gorur</div><div>&nbsp;</div><div>herkonuda oldugu gıbı&nbsp;bu konudada&nbsp;muhalefet durumlar elbet olacak. herkesın aynı fıkırde olması beklenemez. ama onlarında kendılerınce haklı yonlerı var. cunku pıyasada lpg yuzunden sorun cıkaran araclarda var. ama burada suc lpg yakıtında veya sıstemınde degıl. montajcıda ıs bıtıyor. ayrıca bılende konusuyor bılmeyende :))</div><div>&nbsp;</div><div>usta ya sorunu bulamıyor&nbsp;yada dogru ayarı, uygulamayı yapamıyor. cunku bu ıs oyle otomatık kalıbrasyonla tık dıye cozulecek kadar basıt degıl... bırcok usta ısının geregını yapmadıgı veya yapamadıgı ıcın bu tarz sorunlar yasanıyor. bazı ustaların teknık bılgılerı o kadar yetersızkı "lpgde arıza ısıgının yanması normaldır", "motor lpg yı tanımadı" vs gıbı delı sacması cumleler kurarlar. sorsan 15 senelık lpg ustasıyım der. ama hıcbırseyden anlamazz...</div><div>&nbsp;</div><div>duzgun bır yerde montaj yaptırırsan hıcbır sorun yasamazsın... bende kendı aracımdan kısaca bahsedeyım. 96.000 de taktım suan 122.000de tık yok. hemde mobıl 0-40 yag kullanıyorum...</div><div>&nbsp;</div><div>zaten hıc uzaga gıtmeye gerek yok. sıfır alınıp tartarını marka sıralı sıstem takılmıs bır dacıa logan 1.6 8V 90bg makıne suanda kmsı 450.000 cıvarında hala motoru acılmadı... daha otesı varmı? sıfır sahın dogan taksıler 250.000 km de motor acarlardı. </div><div>&nbsp;</div><div>250.000 km de arabaya motor yapsan ne olur kı?? yapacagın tasarruf mıktarı motorunu kac kere yaptırır bılıyormusun??? <img src="http://forum.peugeotturkey.com/smileys/smiley4.gif" height="18" width="18" border="0" alt="Sırıtma" title="Sırıtma" /><img src="http://forum.peugeotturkey.com/smileys/smiley4.gif" height="18" width="18" border="0" alt="Sırıtma" title="Sırıtma" /><img src="http://forum.peugeotturkey.com/smileys/smiley4.gif" height="18" width="18" border="0" alt="Sırıtma" title="Sırıtma" /></div></td></tr></table><br>Aynen katılıyorum.<br>]]>
   </description>
   <pubDate>Thu, 19 May 2011 01:56:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219581&amp;title=206-lpg-bilgi#219581</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : 1.4 color line arac&#305;ma 86.000...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219539&amp;title=206-lpg-bilgi#219539</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5971">emrnl</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2011 Saat 00:45<br /><br />1.4 color line aracıma 86.000 de brc marka lpg taktırdım suan 110.000 de ve hiç bir sorun yaşamadım. bu arada serviste taktırmanı öneririm arada 100 tl civarında bi fiyat farkı var.]]>
   </description>
   <pubDate>Thu, 19 May 2011 00:45:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219539&amp;title=206-lpg-bilgi#219539</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : bu arada cecoli arkada&#351; bu i&#351;lerden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219533&amp;title=206-lpg-bilgi#219533</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2948">trigger</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2011 Saat 00:19<br /><br />bu arada cecoli arkadaş bu işlerden anlıyor, ben sadece kullanıp memnun kaldığım için önerebiliyorum, her türlü yardımcı olurum işleri kararlaştırdığında]]>
   </description>
   <pubDate>Thu, 19 May 2011 00:19:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219533&amp;title=206-lpg-bilgi#219533</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : xt modellerinde ender de olsa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219529&amp;title=206-lpg-bilgi#219529</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2948">trigger</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2011 Saat 00:18<br /><br />xt modellerinde ender de olsa 16v 90 bg motor var. 207 dekinin hatta c4 dekinin aynısı...]]>
   </description>
   <pubDate>Thu, 19 May 2011 00:18:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219529&amp;title=206-lpg-bilgi#219529</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : &#305;mzas&#305;nda 16V yazm&#305;s ama 206 larda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219439&amp;title=206-lpg-bilgi#219439</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2011 Saat 20:09<br /><br />ımzasında 16V yazmıs ama 206 larda 1.4 16v motor varmı hatırlayamadım]]>
   </description>
   <pubDate>Wed, 18 May 2011 20:09:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219439&amp;title=206-lpg-bilgi#219439</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : 1.4 Gibime Geldi Usta   ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219438&amp;title=206-lpg-bilgi#219438</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2011 Saat 20:01<br /><br /><b>1.4 Gibime Geldi Usta&nbsp;</b>]]>
   </description>
   <pubDate>Wed, 18 May 2011 20:01:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219438&amp;title=206-lpg-bilgi#219438</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : r&#305;ca eder&#305;m. mak&#305;ne 1.4 mu 1.6...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219381&amp;title=206-lpg-bilgi#219381</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2011 Saat 16:28<br /><br />rıca ederım. makıne 1.4 mu 1.6 mı?]]>
   </description>
   <pubDate>Wed, 18 May 2011 16:28:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219381&amp;title=206-lpg-bilgi#219381</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : Arkada&#351;lar forumda bu ve buna...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219377&amp;title=206-lpg-bilgi#219377</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6196">lomax</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2011 Saat 16:19<br /><br />Arkadaşlar forumda bu ve buna benzer başlıklar olmasına rağmen dikkat etmeyerek ve aslında bunu bilmeyerek başlığı açmama rağmen ayrıntılı ve bilgili mesajlarınız için çok teşekkür ederim. Bu herşeyden önce buradaki insanların ne kadar usluplu ve saygılı olduğunu gösterir buda herşeyden önce gelir...<br><br>Bir kaç yere bakıcam ama sanırım trigger arkadaşımızın dediği yerde yani derince fs otogaz'da taktırabilirim ve buna kesin karar verirsem hem trigger arkadaşımdan hemde CeColi arkadaşımdan en azından araca takılırken ki bir iki ayrıntıyı isteyebilirim, tekrar çok teşekkürler.]]>
   </description>
   <pubDate>Wed, 18 May 2011 16:19:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=219377&amp;title=206-lpg-bilgi#219377</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : fs otogaz&#305;n ac&#305;l&#305;m&#305;,Faruk Sevg&#305;l&#305;den...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218752&amp;title=206-lpg-bilgi#218752</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mayıs&nbsp;2011 Saat 10:23<br /><br /><P>fs otogazın acılımı,&nbsp;Faruk Sevgılıden gelıyor dıye hatırlıyorum. ya oranın sahıbı yada yetkılısı</P><DIV></DIV><DIV></DIV>lpg sıstemı konusunda atıker safe fast, lovato, zavolı, brc vs kullanabılırsın. kıtıne gore lambda baglantılarını yaptırırsan cokta guzel calısır tereyagı gıbı olur. hepsı senın motorun ıle duzgun calısacak kıtler. fakat montaj ve ayardan dolayı olusabılecek sorunlar usta faktorunu ortaya cıkarıyor. <DIV>&nbsp;</DIV><DIV>lpg duzgun montajlanırsa cekıste vs hıcbır sorun olmaz. bunu kendı aracımla&nbsp;otoyoldada ıspat ettım yanı... ısteyen vıdeoyu ızler&nbsp;gorur</DIV><DIV>&nbsp;</DIV><DIV>herkonuda oldugu gıbı&nbsp;bu konudada&nbsp;muhalefet durumlar elbet olacak. herkesın aynı fıkırde olması beklenemez. ama onlarında kendılerınce haklı yonlerı var. cunku pıyasada lpg yuzunden sorun cıkaran araclarda var. ama burada suc lpg yakıtında veya sıstemınde degıl. montajcıda ıs bıtıyor. ayrıca bılende konusuyor bılmeyende :))</DIV><DIV>&nbsp;</DIV><DIV>usta ya sorunu bulamıyor&nbsp;yada dogru ayarı, uygulamayı yapamıyor. cunku bu ıs oyle otomatık kalıbrasyonla tık dıye cozulecek kadar basıt degıl... bırcok usta ısının geregını yapmadıgı veya yapamadıgı ıcın bu tarz sorunlar yasanıyor. bazı ustaların teknık bılgılerı o kadar yetersızkı "lpgde arıza ısıgının yanması normaldır", "motor lpg yı tanımadı" vs gıbı delı sacması cumleler kurarlar. sorsan 15 senelık lpg ustasıyım der. ama hıcbırseyden anlamazz...</DIV><DIV>&nbsp;</DIV><DIV>duzgun bır yerde montaj yaptırırsan hıcbır sorun yasamazsın... bende kendı aracımdan kısaca bahsedeyım. 96.000 de taktım suan 122.000de tık yok. hemde mobıl 0-40 yag kullanıyorum...</DIV><DIV>&nbsp;</DIV><DIV>zaten hıc uzaga gıtmeye gerek yok. sıfır alınıp tartarını marka sıralı sıstem takılmıs bır dacıa logan 1.6 8V 90bg makıne suanda kmsı 450.000 cıvarında hala motoru acılmadı... daha otesı varmı? sıfır sahın dogan taksıler 250.000 km de motor acarlardı. </DIV><DIV>&nbsp;</DIV><DIV>250.000 km de arabaya motor yapsan ne olur kı?? yapacagın tasarruf mıktarı motorunu kac kere yaptırır bılıyormusun??? <img src="http://forum.peugeotturkey.com/smileys/smiley4.gif" height="18" width="18" border="0" alt="Sırıtma" title="Sırıtma" /><img src="http://forum.peugeotturkey.com/smileys/smiley4.gif" height="18" width="18" border="0" alt="Sırıtma" title="Sırıtma" /><img src="http://forum.peugeotturkey.com/smileys/smiley4.gif" height="18" width="18" border="0" alt="Sırıtma" title="Sırıtma" /></DIV><span style="font-size:10px"><br /><br />Düzenleyen CeCoLi - 17&nbsp;Mayıs&nbsp;2011 Saat 10:30</span>]]>
   </description>
   <pubDate>Tue, 17 May 2011 10:23:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218752&amp;title=206-lpg-bilgi#218752</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : &amp;#039;&amp;#039;toprakk&amp;#039;&amp;#039;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218727&amp;title=206-lpg-bilgi#218727</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5565">boraa</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mayıs&nbsp;2011 Saat 09:20<br /><br />''toprakk'' kardeş %100 haklı emin olun lpg taktıran araçların % 95 i kısa vadede olmasa bile uzun vadede kesin uyumsuzluk ve arıza veriyor.benim çevremde çok arkadaşım bin pişman.hatta ve hatta söktürende var.boşuna aracınızın orijinalliğini bozmayın.]]>
   </description>
   <pubDate>Tue, 17 May 2011 09:20:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218727&amp;title=206-lpg-bilgi#218727</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi :  Say&#305;n lomax &#246;ncelikle arac&#305;n&#305;z...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218702&amp;title=206-lpg-bilgi#218702</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mayıs&nbsp;2011 Saat 03:44<br /><br />Sayın lomax öncelikle aracınız hayırlı olsun.<br>Forumumuza hoşgeldiniz.<br>2000model Peugeot 206 XT 1.6 8V aracım var. Aracımın eski sahibi atiker LPG dönüşümü yaptırmış. Ben gayet memnunum.<br>Peugeotlara LPG uymaz diyen arkadaşlar bence LPG dönüşümü sırasında kötü ustalara denk geldiler.<br>Aracın LPGye uyum sağlaması ve yakıt tasarrufu sağlaması için öncelikle kaliteli ve uygun bir LPG dönüşüm sistemi şarttır. İkinci ana etken ise ustadır.<br>Şahsi fikrimdir.<br>Saygılarımla.<br><span style="font-size:10px"><br /><br />Düzenleyen mustiii - 17&nbsp;Mayıs&nbsp;2011 Saat 03:44</span>]]>
   </description>
   <pubDate>Tue, 17 May 2011 03:44:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218702&amp;title=206-lpg-bilgi#218702</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi : rica edderim, di&#287;er g&#246;r&#252;&#351;leri...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218646&amp;title=206-lpg-bilgi#218646</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2948">trigger</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mayıs&nbsp;2011 Saat 00:02<br /><br />rica edderim, diğer görüşleri de al, özellikle atiker den anlayan arkadaşın da görüşlerini dinlemek gerek. sonra da diğer sorularını ben elimden geldiğince cevaplarım.&nbsp;<div>önemli olan marka değil ustalık denir, ben yaptırdığım yerin bu özelliğine de güveniyorum.</div>]]>
   </description>
   <pubDate>Tue, 17 May 2011 00:02:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218646&amp;title=206-lpg-bilgi#218646</guid>
  </item>
  <item>
   <title><![CDATA[206 Lpg bilgi :    trigger Yazd&#305;:206 xline 2004...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218630&amp;title=206-lpg-bilgi#218630</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6196">lomax</a><br /><strong>Konu:</strong> 14893<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Mayıs&nbsp;2011 Saat 23:21<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: trigger" alt="Orjinalini yazan: trigger" style="vertical-align: text-bottom;" /> <strong>trigger Yazdı:</strong><br /><br />206 xline 2004 model aracma ben de lpg taktırmıştım. derince fs otogaz da taktırdım. 50000 km kullandım bir sorun olmadı. hafif bir tekleme farkedip söylediğimde garantiden enjektör değiştirdiler sorun halloldu. arkadaşlardan da tavsiye al ama benim önerim orasıdır. 2.pejo arabam ikisinde de sorun olmadı. soruların için bana ulaşabilirsin</td></tr></table><br><br>teşekkürler, bilgilerinizden yararlanmak aynı şehirde olduğumuzdan hem daha kolay hemde daha iyi olur hemde kocaeli üyelerini kalabalıklaştırmış oluruz :)<br>]]>
   </description>
   <pubDate>Mon, 16 May 2011 23:21:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14893&amp;PID=218630&amp;title=206-lpg-bilgi#218630</guid>
  </item>
 </channel>
</rss>
