 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 306 kalorifer motoru</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 306 : 306 kalorifer motoru]]></description>
  <pubDate>Mon, 04 May 2026 01:13:22 +0000</pubDate>
  <lastBuildDate>Thu, 23 Apr 2015 21:33:04 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=14101</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[306 kalorifer motoru : bana yardimci olacak kimse yokmu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=542714&amp;title=306-kalorifer-motoru#542714</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16071">rahmi</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Nisan&nbsp;2015 Saat 21:33<br /><br />bana yardimci olacak kimse yokmu]]>
   </description>
   <pubDate>Thu, 23 Apr 2015 21:33:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=542714&amp;title=306-kalorifer-motoru#542714</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : merhaba.benim 1998model 306 griffe...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=542713&amp;title=306-kalorifer-motoru#542713</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16071">rahmi</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Nisan&nbsp;2015 Saat 21:27<br /><br /><span style="line-height: 16.7999992370605px; : rgb251, 251, 253;">merhaba.benim 1998model 306 griffe var.kalorifer sogukufluyor kisin bir turlu isinmadi kisa dogru antifiriz koymaya gec kaldim araba dondu sonra &nbsp;calistirip antifriz koydum birdahada isinmadi.sanayiye goturdum petek tikali dediler.ama sicak havalarda normalisiniyor sadec soguk havalarda isinmiyor bana yardimci olurmusunuz birde bu arabada soguk sicak musur varmidir.acaba devir daimde bir sorun varmidir birde soguk havalarda sogukufleyince fani kapatiyorum 15 dakika sonra aciyorum sicak ufluyor sonrada yava yavs soguyor</span><div><span style="line-height: 16.7999992370605px; : rgb251, 251, 253;"><br></span></div><div><span style="line-height: 16.7999992370605px; : rgb251, 251, 253;"><br></span></div><span style="font-size:10px"><br /><br />Düzenleyen rahmi - 23&nbsp;Nisan&nbsp;2015 Saat 21:30</span>]]>
   </description>
   <pubDate>Thu, 23 Apr 2015 21:27:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=542713&amp;title=306-kalorifer-motoru#542713</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : Herkese Merhaba Arkada&#351;lar,1)98...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=528559&amp;title=306-kalorifer-motoru#528559</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15315">balabano</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Aralık&nbsp;2014 Saat 20:19<br /><br />Herkese Merhaba Arkadaşlar,<div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">1)&nbsp;</span><span style="line-height: 1.4;">98 model 306 Sedan Griffe kullanıcısıyım. Kalorifer fanı sağlıklı çalışmıyor. Yetkili serviste 800 liralık masrafı olduğu söylendi fakat bu tutar içinde bulunduğum dönemde ödeyebileceğim bir miktar değil. Sonrasında bir çözüm buldular ama aradan 20 gün geçti yine aynı sorunu yaşıyorum. Çalıştığında ısıtmasında herhangi bir problem yok, zaten bildiğiniz gibi kontağı açır açmaz kalorifer motoru çalışıyor fakat fan her zaman üflemiyor. Bir soket çıkması olabilir mi ya da sorunun kaynağı sizce ne olabilir?</span></div><div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">2) 4'lü flaşör tuşu yanındaki cam ısıtma tuşuna bastığımda aracın devri düşüyor, nedeni nedir, normal midir? Bir sorun ise çözümü nedir?</span></div><div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">3) Orta konsoldaki dijital saatte, göstergedeki bazı digital parçaların ışığı yanmıyor, örneğin göstergede 0'ı oluşturan parçaların 2'si yanmıyor, sorunun nedeni ve çözümü nedir?,</span></div><div><span style="line-height: 1.4;"><br></span></div><div>Şimdiden teşekkür ederim, keyifli forumlar...</div><div><br></div><div><br></div>]]>
   </description>
   <pubDate>Fri, 19 Dec 2014 20:19:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=528559&amp;title=306-kalorifer-motoru#528559</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru :    koliva Yazd&#305;:   Griffe...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=354751&amp;title=306-kalorifer-motoru#354751</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7169">Griffe</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2012 Saat 18:11<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: koliva" alt="Orjinalini yazan: koliva" style="vertical-align: text-bottom;" /> <strong>koliva Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Griffe" alt="Orjinalini yazan: Griffe" style="vertical-align: text-bottom;" /> <strong>Griffe Yazdı:</strong><br /><br /><br><br>merhaba..<br><br>peki bu dizayn aracın yakıtına etki eder mi..? <br></td></tr></table><br><br>Neden boyle birsey dusundunuz ki? Bence etkilemez. <br></td></tr></table><br><br>aracım sanırım biraz falz yakıyor..306 98 modfel griffe..400-500 şehir içi.. genel olarak zaten fazla yaktığını söykeyeceksiz ama ne biliyim belki etkisi olabileceğini düşündüm. (gerçi o kadar az çalışmayla nasıl etkisi olsun ama)..<br><br><br>]]>
   </description>
   <pubDate>Thu, 29 Mar 2012 18:11:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=354751&amp;title=306-kalorifer-motoru#354751</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru :    Griffe Yazd&#305;: merhaba..peki...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=354748&amp;title=306-kalorifer-motoru#354748</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2012 Saat 17:54<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Griffe" alt="Orjinalini yazan: Griffe" style="vertical-align: text-bottom;" /> <strong>Griffe Yazdı:</strong><br /><br /><br><br>merhaba..<br><br>peki bu dizayn aracın yakıtına etki eder mi..? <br></td></tr></table><br><br>Neden boyle birsey dusundunuz ki? Bence etkilemez. <br>]]>
   </description>
   <pubDate>Thu, 29 Mar 2012 17:54:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=354748&amp;title=306-kalorifer-motoru#354748</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru :    malazgirt18 Yazd&#305;:Merhaba...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=354745&amp;title=306-kalorifer-motoru#354745</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7169">Griffe</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2012 Saat 17:50<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: malazgirt18" alt="Orjinalini yazan: malazgirt18" style="vertical-align: text-bottom;" /> <strong>malazgirt18 Yazdı:</strong><br /><br />Merhaba Arkadaşım <br><br>306 da kalörfer motorunun sürekli çalışması bir sorun değil orjinalinde olan birşey istersen araya anahtar koydurup tamamen kapatabilirsin motorun cızırtılı çalışması içinde nemlenmiştir dediğin gibi yağlayınca düzelir ancak kontağı cevirmenle birlikte kalörifer motoru çalışır bu bir sorun değil dizayndır<br><br></td></tr></table><br><br>merhaba..<br><br>peki bu dizayn aracın yakıtına etki eder mi..? <br>]]>
   </description>
   <pubDate>Thu, 29 Mar 2012 17:50:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=354745&amp;title=306-kalorifer-motoru#354745</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : Merhaba Arkada&#351;&#305;m 306 da kal&#246;rfer...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=347592&amp;title=306-kalorifer-motoru#347592</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7356">malazgirt18</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Şubat&nbsp;2012 Saat 08:47<br /><br />Merhaba Arkadaşım <br><br>306 da kalörfer motorunun sürekli çalışması bir sorun değil orjinalinde olan birşey istersen araya anahtar koydurup tamamen kapatabilirsin motorun cızırtılı çalışması içinde nemlenmiştir dediğin gibi yağlayınca düzelir ancak kontağı cevirmenle birlikte kalörifer motoru çalışır bu bir sorun değil dizayndır<br><br>]]>
   </description>
   <pubDate>Thu, 09 Feb 2012 08:47:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=347592&amp;title=306-kalorifer-motoru#347592</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru :    codemaster Yazd&#305;:merhabalar,foruma...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=347591&amp;title=306-kalorifer-motoru#347591</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7356">malazgirt18</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Şubat&nbsp;2012 Saat 08:46<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: codemaster" alt="Orjinalini yazan: codemaster" style="vertical-align: text-bottom;" /> <strong>codemaster Yazdı:</strong><br /><br />merhabalar,&nbsp;<div>foruma yeni üye oldum, şahane bir forum.&nbsp;</div><div>benim sorunum hiç susmayan ve cızırtılı çalışan kalorifer motoru.&nbsp;</div><div>haftasonu kalorifer düğmesinde temassızlık vardır, ondan dolayı tam kapanmıyordur düşüncesi ile konsolü söktüm. düğmede sorunu düzeltecek bişey bulamadım. topladım bi daha. sonra sanayiye gittim. torpidonun altından kalorifer motorunu söktüler, yağladılar, cızırtılı çalışması sona erdi ama yine de çok hafiften üflüyor ha bire.&nbsp;</div><div><br></div><div>Birinci olarak şunu sorayım, torpidonun altında kalorifer motorunu gizleyen bir plaka var, plaka ordaki bir boruya bağlı, klips gibi bişey var, sanayide usta bi hamlede çıkarmıştı o korumayı ama ben bir türlü sökemedim. detaylı anlatabilecek olan varsa çok duacı olurum.&nbsp;</div><div><br></div><div>ikinci olarak da diyorum ki kalorifer motoruna giren kabloların birine (elektrik getiren) basit bir anahtar takayım. kaloriferi çalıştıracağım zaman uzanır açarım o düğmeden. çünkü sanırım 306ların hiç kapanmayan kalorifer motoru kronik bir sorunmuş.</div></td></tr></table>]]>
   </description>
   <pubDate>Thu, 09 Feb 2012 08:46:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=347591&amp;title=306-kalorifer-motoru#347591</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : merhabalar,foruma yeni &#252;ye oldum,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=318519&amp;title=306-kalorifer-motoru#318519</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7725">codemaster</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ekim&nbsp;2011 Saat 15:52<br /><br />merhabalar,&nbsp;<div>foruma yeni üye oldum, şahane bir forum.&nbsp;</div><div>benim sorunum hiç susmayan ve cızırtılı çalışan kalorifer motoru.&nbsp;</div><div>haftasonu kalorifer düğmesinde temassızlık vardır, ondan dolayı tam kapanmıyordur düşüncesi ile konsolü söktüm. düğmede sorunu düzeltecek bişey bulamadım. topladım bi daha. sonra sanayiye gittim. torpidonun altından kalorifer motorunu söktüler, yağladılar, cızırtılı çalışması sona erdi ama yine de çok hafiften üflüyor ha bire.&nbsp;</div><div><br></div><div>Birinci olarak şunu sorayım, torpidonun altında kalorifer motorunu gizleyen bir plaka var, plaka ordaki bir boruya bağlı, klips gibi bişey var, sanayide usta bi hamlede çıkarmıştı o korumayı ama ben bir türlü sökemedim. detaylı anlatabilecek olan varsa çok duacı olurum.&nbsp;</div><div><br></div><div>ikinci olarak da diyorum ki kalorifer motoruna giren kabloların birine (elektrik getiren) basit bir anahtar takayım. kaloriferi çalıştıracağım zaman uzanır açarım o düğmeden. çünkü sanırım 306ların hiç kapanmayan kalorifer motoru kronik bir sorunmuş.</div>]]>
   </description>
   <pubDate>Mon, 24 Oct 2011 15:52:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=318519&amp;title=306-kalorifer-motoru#318519</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : 306 dada cok kolay yaaa :)) alt...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202610&amp;title=306-kalorifer-motoru#202610</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Nisan&nbsp;2011 Saat 08:54<br /><br />306 dada cok kolay yaaa :)) alt korumayı cıkardıgın gıbı motor anında onune kalıyor zaten :) rezıstansta motorun hemen yanında. bunun ıcın 4 tork vıdayı sokup motoru cıkarman gereklı.&nbsp;en azından benımkınde oyle :))]]>
   </description>
   <pubDate>Wed, 13 Apr 2011 08:54:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202610&amp;title=306-kalorifer-motoru#202610</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : s&#252;per payla&#351;&#305;mlar elinize emeg&#305;n&#305;ze...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202595&amp;title=306-kalorifer-motoru#202595</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4964">ugur_clskn</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Nisan&nbsp;2011 Saat 01:28<br /><br />süper paylaşımlar elinize emegınıze saglık. sımdı bıraz arastırdım bende. 307 nın &nbsp;motoru &nbsp;sıgorta panelının orda &nbsp;dıreksıyon mılıne cok yakın konumlandırılmıs reosta da hemen motorun yanında ıdı &nbsp;keske 306 da da orda olsaydı problem onda olsaydı halletmek basıt olucaktı. cok uzun ıs sıleceklerı sokmek o ızgarayı felan neyse artık basa geldı bakıcaz. kolıva abı cok tesekkur ederım resımler cok bılgılendırıcı oldu benım ıcın. motor reostaya gore daha kolay yerde oldugu ıcın once onun soketlerıne bakmak ısıtıyorum fanı devreye aldıgımda akım gelıyo mu. gelmıyor ıse reostayı kontrol edıcem. bırde rolesı varmıs &nbsp;sanırım çünki sıgorta tablosunda hem kalorıfer motoru sıgortası 30 amper dıyo hemde kalorıfer motoru rolesı dıyo 10 amper buyuk ıhtımal role uzerınden beslemısler. Bır konu daha varkı fan calıstırma kolunun ıçındekı kalın telın ne olduguna anlam veremıyordum &nbsp;kolıva abının koydugu resımdekı reostayı gorunce anlam kazandı sanırım reostanın dırencı degıstırmesı ıcın gereklı mekanık hareketı saglıyor.<div>Pekıyı &nbsp;bırkac gun ıcınde mutlaka bakacagım sızı haberdar ederım resımleyıp konu anlatımlı paylasmak ıstıyorum.&nbsp;</div><div>Tekrar çok tesekkurler paylasımlarınız ıcın</div>]]>
   </description>
   <pubDate>Wed, 13 Apr 2011 01:28:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202595&amp;title=306-kalorifer-motoru#202595</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : evet evet paspasa...  tab&#305; oncel&#305;kle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202543&amp;title=306-kalorifer-motoru#202543</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Nisan&nbsp;2011 Saat 00:07<br /><br />evet evet paspasa...<DIV>&nbsp;</DIV><DIV>tabı oncelıkle oraya takılan gecme korumaya akacak&nbsp;onunda altından paspasa... normalde motorun ustune su gelmemesı lazım zaten. su akarları tıkanmazsa su gırmez. aracın bu noktası bıraz dandık olmus dıyecegım ama 307 de daha beter hata yapılmıs bsı ın ustune su ınıyorr :DDDDDD&nbsp; 206 desen polen fıltresı kabak gıbı ortada duruyor... acaba peugeot bunları bılınclı mı yapıyor dıye dusunuyorum :)))))))</DIV>]]>
   </description>
   <pubDate>Wed, 13 Apr 2011 00:07:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202543&amp;title=306-kalorifer-motoru#202543</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru :    cecoli Yazd&#305;:kol&#305;va res&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202539&amp;title=306-kalorifer-motoru#202539</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Nisan&nbsp;2011 Saat 00:02<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: cecoli" alt="Orjinalini yazan: cecoli" style="vertical-align: text-bottom;" /> <strong>cecoli Yazdı:</strong><br /><br /><p>kolıva resım 10 numara... tam ustune bastın :))))))&nbsp;benım aractakı sıstem&nbsp;resımdekıyle aynı :)))</p><div>benım motorun altında ufak bır cıkıntı var fakat&nbsp;hortum yok. bende o&nbsp;cıkıntıyı motorun ustunde su gelırse motorun ıcınde dolmayıp asagı akması ıcın dıye dusunuyordum. dogru dusunmusum.&nbsp;fakat senın koydugum resımde hortumla camurlugun ıcıne dogru yonlendırılımıs. acaba o boru orjınal mı&nbsp;bılemedım :))&nbsp;&nbsp; yan saca bakmam lazım. delık var ıse orjınal olabılır. ama ben delık falan gormedım... belkı sonradanda yapılmıs olabılır...</div></td></tr></table><br><br>Asagi derken paspasa mi? <br><br>Bence bu resim de baska bir 306 modelinden alinti. Masallah Peugeot, 306'yi uretirken her araca farkli bir olay katmis <img src="https://forum.peugeotturkey.com/smileys/smiley11.gif" border="0" alt="Wall" title="Wall" /><br>]]>
   </description>
   <pubDate>Wed, 13 Apr 2011 00:02:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202539&amp;title=306-kalorifer-motoru#202539</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru : kol&#305;va res&#305;m 10 numara... tam...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202537&amp;title=306-kalorifer-motoru#202537</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Nisan&nbsp;2011 Saat 23:55<br /><br /><P>kolıva resım 10 numara... tam ustune bastın :))))))&nbsp;benım aractakı sıstem&nbsp;resımdekıyle aynı :)))</P><DIV>benım motorun altında ufak bır cıkıntı var fakat&nbsp;hortum yok. bende o&nbsp;cıkıntıyı motorun ustunde su gelırse motorun ıcınde dolmayıp asagı akması ıcın dıye dusunuyordum. dogru dusunmusum.&nbsp;fakat senın koydugum resımde hortumla camurlugun ıcıne dogru yonlendırılımıs. acaba o boru orjınal mı&nbsp;bılemedım :))&nbsp;&nbsp; yan saca bakmam lazım. delık var ıse orjınal olabılır. ama ben delık falan gormedım... belkı sonradanda yapılmıs olabılır...</DIV>]]>
   </description>
   <pubDate>Tue, 12 Apr 2011 23:55:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202537&amp;title=306-kalorifer-motoru#202537</guid>
  </item>
  <item>
   <title><![CDATA[306 kalorifer motoru :  O halde arkadasin arabasinin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202533&amp;title=306-kalorifer-motoru#202533</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 14101<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Nisan&nbsp;2011 Saat 23:49<br /><br /><br>O halde arkadasin arabasinin hangisinden oldugunu bilmek gerekiyor. Bu kadar farklilik oldugunu da ilk defa gordum <img src="https://forum.peugeotturkey.com/smileys/smiley36.gif" border="0" alt="Kahkaha" title="Kahkaha" /> Herneyse o zaman soyle bisey daha soyleyebilirim senin ilk yazdiklarina paralel olarak. Bu motorun baglanti soketinde de sorunlar cikabiliyor. Sanirim su motor resmi dogdudur:<br><img src="http://images.forum-auto.com/mesimages/254031/boite02.jpg" border="0" /><br><br>Bu kirmizi ile cizili baglanti soketinde sorun cikabiliyor. <br><br><img src="http://images.forum-auto.com/mesimages/797299/prise.jpg" border="0" /><br><br><font size="1">Fotograflar: http://www.forum-auto.com</font><br>]]>
   </description>
   <pubDate>Tue, 12 Apr 2011 23:49:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=14101&amp;PID=202533&amp;title=306-kalorifer-motoru#202533</guid>
  </item>
 </channel>
</rss>
