 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307 xt 2.0 hdi 2002</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : 307 xt 2.0 hdi 2002]]></description>
  <pubDate>Mon, 04 May 2026 08:20:04 +0000</pubDate>
  <lastBuildDate>Sun, 30 Jan 2011 22:29:02 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=12504</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 :    cerci07 Yazd&#305;:fap arizasi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177232&amp;title=307-xt-2-0-hdi-2002#177232</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ocak&nbsp;2011 Saat 22:29<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: cerci07" alt="Orjinalini yazan: cerci07" style="vertical-align: text-bottom;" /> <strong>cerci07 Yazdı:</strong><br /><br />fap arizasi olamaz fap arizasinda EFF.DESENCRASEMENT FILTRE DIESEL FAP diye bir ariza raporu cikar ekranda daha sonralari anomali antipolution da EFF.DESENCRASEMENT FILTRE DIESEL FAP ile birlikte cikar ve turkiyede&nbsp; fapli arac yok galiba benim bildigim&nbsp;</td></tr></table><br><br>Hocam senin dedigin "EFF.DESENCRASEMENT FILTRE DIESEL FAP" hatasi, Fap filtresi tikali oldugu zamanlarda aliniyor. Alinan hata genel bir hata oldugundan bunu da kapsayabiliyor. Onceki yazimda da belirttigim gibi bilgisayara baglayip hata kodunun ogrenilmesi gerek.<br>]]>
   </description>
   <pubDate>Sun, 30 Jan 2011 22:29:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177232&amp;title=307-xt-2-0-hdi-2002#177232</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : fap arizasi olamaz fap arizasinda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177208&amp;title=307-xt-2-0-hdi-2002#177208</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=803">cerci07</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ocak&nbsp;2011 Saat 21:46<br /><br />fap arizasi olamaz fap arizasinda EFF.DESENCRASEMENT FILTRE DIESEL FAP diye bir ariza raporu cikar ekranda daha sonralari anomali antipolution da EFF.DESENCRASEMENT FILTRE DIESEL FAP ile birlikte cikar ve turkiyede&nbsp; fapli arac yok galiba benim bildigim&nbsp;]]>
   </description>
   <pubDate>Sun, 30 Jan 2011 21:46:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177208&amp;title=307-xt-2-0-hdi-2002#177208</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 :        komando Yazd&#305;:evet...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177098&amp;title=307-xt-2-0-hdi-2002#177098</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ocak&nbsp;2011 Saat 14:25<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: komando" alt="Orjinalini yazan: komando" style="vertical-align: text-bottom;" /> <strong>komando Yazdı:</strong><br /><br />evet kardeş belli bir devir ve hızı geçemiyorum ve gaz yemiyor stop edip bekledikten sonra çalışıyor gidiyor ama sonra yine aynı oluyr lütfen yardım edib bana</td></tr></table><br><br>Hocam bu sorunun bilgisayara baglanmadan ortadan kaldirilmasi samanlikta igne aramak gibi bisey. Dedigim gibi genel bir hata bu. Herbiseyden kaynaklanabilir. Aracin guvenli moda girmesi, araca daha fazla zarar vermemek adina gelistirilmis bir koruma mekanizmasidir. Ufak bir sorun da olabilir buyuk te. Okutturmadan bilemeyiz.<br><br>Yine de:<br>Arastirdigim kadariyla bu hatayi FAP filtresi yuzunden alanlar cok. Sizin aracinizda FAP var mi yok mu bilmiyorum. Bir kontrol edin isterseniz. Aracinizin kilometresinin de yuksek olmasi bu ihtimali kuvvetlendiriyor ama dedigim gibi FAP varsa. Bu arada FAP varsa degistirilmesi bayagi bi pahali.<br>Ayni hatayi mazot filtresi yuzunden alanlar da var. Ona da bir baktirabilirsiniz.<br>Trigger kayisindan da kaynaklanabiliyor. Yakin zamanda degistirmisseniz cok siki ya da cok gecsek birakilmissa da yapabilir.<br><br>Sonuc olarak, bilgisayara baglatmaktan baska bir cozum yok gibi. Araci okuttugunuzda eger hata kodunu bizzat alabiliyorsaniz gelin buraya yazin. O zaman cok daha isabetli kararlar verilebilir.<br><br>Gecmis olsun.<br><span style="font-size:10px"><br /><br />Düzenleyen koliva - 30&nbsp;Ocak&nbsp;2011 Saat 14:27</span>]]>
   </description>
   <pubDate>Sun, 30 Jan 2011 14:25:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177098&amp;title=307-xt-2-0-hdi-2002#177098</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : 143.000 de ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177088&amp;title=307-xt-2-0-hdi-2002#177088</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5052">komando</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ocak&nbsp;2011 Saat 13:48<br /><br />143.000 de ]]>
   </description>
   <pubDate>Sun, 30 Jan 2011 13:48:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177088&amp;title=307-xt-2-0-hdi-2002#177088</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : 143.000 de karde&#351; bildi&#287;ein bir&#351;ey...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177087&amp;title=307-xt-2-0-hdi-2002#177087</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5052">komando</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ocak&nbsp;2011 Saat 13:47<br /><br />143.000 de kardeş bildiğein birşey varsa yardım cı ol<DIV></DIV>]]>
   </description>
   <pubDate>Sun, 30 Jan 2011 13:47:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177087&amp;title=307-xt-2-0-hdi-2002#177087</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : evet karde&#351; belli bir devir ve...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177085&amp;title=307-xt-2-0-hdi-2002#177085</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5052">komando</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ocak&nbsp;2011 Saat 13:46<br /><br />evet kardeş belli bir devir ve hızı geçemiyorum ve gaz yemiyor stop edip bekledikten sonra çalışıyor gidiyor ama sonra yine aynı oluyr lütfen yardım edib bana<DIV></DIV>]]>
   </description>
   <pubDate>Sun, 30 Jan 2011 13:46:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=177085&amp;title=307-xt-2-0-hdi-2002#177085</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 :    Antipollution fault hatasi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176645&amp;title=307-xt-2-0-hdi-2002#176645</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ocak&nbsp;2011 Saat 11:03<br /><br />Antipollution fault hatasi genel olarak motor yonetim hatasidir ve genel bir hatadir. Bilgisayara baglanarak daha spesifik noktalara yonlendirilmelidir. Belli ki servis bilgisayara baglamis ve hatayi gorup biseyler degistirmis ama olmamis. Aslinda sizin yerinizde olsam servise gidip sikayette bulunurdum. Belki biseye yaramayacak ama en azindan icinizi dokerdiniz&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley1.gif" border="0" alt="Gülme" title="Gülme" /><br>Yukarida dedigim gibi bu hata genel bir hatadir ve aracta yonetim kisminda herhangi bir sorun oldugunda bu hata ortaya cikar. Demek istedigim su ki: Bu baslik altinda arkadaslar gelip "bende de ayni sorun vardi sunu yaptim duzeldi" gibi seyler sizin sorununuza buyuk ihtimalle care olmayacaktir. Sansiniz varsa ve onlardan birisiyle ayni sorunla karsi karsiyaysaniz o zaman duzelir ama inanir bu ihtimal dusuk. <br><br>Sonuc olarak, yine servise gidip ya da baska bir servise gidip isi onlara birakmaktan baska care yok gibime geliyor. Ya da diyorsaniz ki ben isi devraliyorum ve bu ise yatkinligim var, o zaman alin bi peugeot planet takin bilgisayarinizi araca ve okuyun hatalari birer birer.<br><br>Belki konuyu biraz daha indirgemek adina soyle bir soru sorabilirim: Arac bu hatayi verdigi anda "limp home mode" a giriyor mu? Bunu Turkcesi sanirim guvenli mod, yani belirli bir deviri ya da hizi(40 mph) gecemiyorsunuz, ya da gaz yemez. Boyle bisey var mi yoksa normal seyrinde devam ediyor mu hersey?<br><span style="font-size:10px"><br /><br />Düzenleyen koliva - 29&nbsp;Ocak&nbsp;2011 Saat 11:08</span>]]>
   </description>
   <pubDate>Sat, 29 Jan 2011 11:03:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176645&amp;title=307-xt-2-0-hdi-2002#176645</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : Aynen bende &#246;yle yapt&#305;m devaml&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176638&amp;title=307-xt-2-0-hdi-2002#176638</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3695">gozem</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ocak&nbsp;2011 Saat 10:49<br /><br />Aynen bende öyle yaptım devamlı yanıyodu kontağı kapatıp açtığımda bi süre yanmasada sonra tekrar ediyordu. yağ değişimi ile birlikte tüm filtreleri değiştirdim o günden sonra hiç yanmadı.<br />kesin çözüm olurmu bilmem ama bende işe yaradı  <img src="https://forum.peugeotturkey.com/smileys/smiley31.gif" border="0" align="middle" /> ]]>
   </description>
   <pubDate>Sat, 29 Jan 2011 10:49:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176638&amp;title=307-xt-2-0-hdi-2002#176638</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : arac&#305;n&#305;n mazot f&#305;ltres&#305;n&#305; deg&#305;st&#305;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176636&amp;title=307-xt-2-0-hdi-2002#176636</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ocak&nbsp;2011 Saat 10:43<br /><br />aracının mazot fıltresını degıstır saglam bı yerden mazot al yoluna devam et 400 tl cok vermıssın servıse]]>
   </description>
   <pubDate>Sat, 29 Jan 2011 10:43:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176636&amp;title=307-xt-2-0-hdi-2002#176636</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : Bu ar&#305;za yetk&#305;l&#305; serv&#305;slerde de...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176558&amp;title=307-xt-2-0-hdi-2002#176558</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2636">Eyüp Duygun</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ocak&nbsp;2011 Saat 00:39<br /><br />Bu arıza yetkılı servıslerde de cok sıkıntı cıkaran bır arıza.Aracınız kac km'de ve kat iptalı varmı ?]]>
   </description>
   <pubDate>Sat, 29 Jan 2011 00:39:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176558&amp;title=307-xt-2-0-hdi-2002#176558</guid>
  </item>
  <item>
   <title><![CDATA[307 xt 2.0 hdi 2002 : ben bu ar&#305;za lambas&#305;n&#305;n sorununu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176538&amp;title=307-xt-2-0-hdi-2002#176538</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5052">komando</a><br /><strong>Konu:</strong> 12504<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ocak&nbsp;2011 Saat 00:10<br /><br />ben bu arıza lambasının sorununu çözdüremedim servise götürdüm sildi ama tekrar yanıyor sarı lamba musluğa benziyor seyir halinde bir den yanıyor yol bilgisayarında apollotion foult yazıyor kenara çekip stop ediyorum 1 dakika bekleyip çalıştıktan sonra sönüyor ama bir süre sonra yine aynnısı oluyor servis 400 tl aldı ama devam ediyor şimdide beyin değişecek diyor bu konu hakkında yardımcı olun lütfen çok canım sıkılıyor]]>
   </description>
   <pubDate>Sat, 29 Jan 2011 00:10:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=12504&amp;PID=176538&amp;title=307-xt-2-0-hdi-2002#176538</guid>
  </item>
 </channel>
</rss>
