 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : partner rölanti devri</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Partner : partner rölanti devri]]></description>
  <pubDate>Sat, 02 May 2026 20:47:01 +0000</pubDate>
  <lastBuildDate>Wed, 27 Oct 2010 21:00:04 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=11098</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[partner rölanti devri : bende berlingo 1.9d vard&#305; benim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=156606&amp;title=partner-rolanti-devri#156606</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Ekim&nbsp;2010 Saat 21:00<br /><br />bende berlingo 1.9d vardı benim kide 10un üstündeydi normal kardeşim]]>
   </description>
   <pubDate>Wed, 27 Oct 2010 21:00:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=156606&amp;title=partner-rolanti-devri#156606</guid>
  </item>
  <item>
   <title><![CDATA[partner rölanti devri :   kasirga85 Yazd&#305;:motor s&#305;cakken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154899&amp;title=partner-rolanti-devri#154899</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3353">Faruk</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2010 Saat 14:14<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: kasirga85" alt="Orjinalini yazan: kasirga85" style="vertical-align: text-bottom;" /> <strong>kasirga85 Yazdı:</strong><br /><br />motor sıcakken de soğukken de aynı rölanti devri yukarıda , motorun gürültülü çalışması bu yüzden mi acaba?</td></tr></table> <DIV>&nbsp;</DIV><DIV>ayar yaptır çözülür..</DIV>]]>
   </description>
   <pubDate>Tue, 19 Oct 2010 14:14:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154899&amp;title=partner-rolanti-devri#154899</guid>
  </item>
  <item>
   <title><![CDATA[partner rölanti devri : benim eni&#351;tede 2006 2.0 hdi var...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154784&amp;title=partner-rolanti-devri#154784</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4187">dogu</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2010 Saat 18:55<br /><br />benim eniştede 2006 2.0 hdi var onun soğukken anca 10 da sıcakkende 10 un 2 birim altında oluyo]]>
   </description>
   <pubDate>Mon, 18 Oct 2010 18:55:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154784&amp;title=partner-rolanti-devri#154784</guid>
  </item>
  <item>
   <title><![CDATA[partner rölanti devri :  motor s&#305;cakken de so&#287;ukken de...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154779&amp;title=partner-rolanti-devri#154779</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4227">kasirga85</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2010 Saat 18:23<br /><br />motor sıcakken de soğukken de aynı rölanti devri yukarıda , motorun gürültülü çalışması bu yüzden mi acaba?<span style="font-size:10px"><br /><br />Düzenleyen kasirga85 - 18&nbsp;Ekim&nbsp;2010 Saat 18:24</span>]]>
   </description>
   <pubDate>Mon, 18 Oct 2010 18:23:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154779&amp;title=partner-rolanti-devri#154779</guid>
  </item>
  <item>
   <title><![CDATA[partner rölanti devri : valla partner bilmem ama benim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154717&amp;title=partner-rolanti-devri#154717</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2523">elnino35</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2010 Saat 13:00<br /><br />valla partner bilmem ama benim araçdada öle oluyor normal sorun teşkil etmiyo ama istersen bi göster gaz teli ayarlarıyla ilgili olması gerekiyo]]>
   </description>
   <pubDate>Mon, 18 Oct 2010 13:00:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154717&amp;title=partner-rolanti-devri#154717</guid>
  </item>
  <item>
   <title><![CDATA[partner rölanti devri : ilk &#231;al&#305;&#351;t&#305;&#287;&#305;nda motor so&#287;ukken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154699&amp;title=partner-rolanti-devri#154699</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3353">Faruk</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2010 Saat 10:54<br /><br />ilk çalıştığında motor soğukken 10 un üstünde oluyo,sonra motor ısınınca 10 un 2 tane altına düşüyo partner 1,9 D de.]]>
   </description>
   <pubDate>Mon, 18 Oct 2010 10:54:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154699&amp;title=partner-rolanti-devri#154699</guid>
  </item>
  <item>
   <title><![CDATA[partner rölanti devri : arkada&#351;lar partner 2005 1.9 D...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154680&amp;title=partner-rolanti-devri#154680</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4227">kasirga85</a><br /><strong>Konu:</strong> 11098<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2010 Saat 02:00<br /><br />arkadaşlar partner 2005 1.9 D araç için rölanti devri kaç olmalı, bizim aracın rölantide gösterge 10' un üstünde 11-12 gibi, bu normal mi? sanırım daha aşağıda olmalı&nbsp;&nbsp;]]>
   </description>
   <pubDate>Mon, 18 Oct 2010 02:00:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=11098&amp;PID=154680&amp;title=partner-rolanti-devri#154680</guid>
  </item>
 </channel>
</rss>
