  Yeni Mesajlar Yeni Mesajlar RSS - Peugeot & Citroen Hata Kodları
Çevrimdışı rifatseker Açılır Kutu Gör
02 - Ağustos - 1981
Aracı : Leon 1.6 TDI IBIZA 1.2 TSI
Kayıt Tarihi: 27 Ekim 2009
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı rifatseker Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Konu: Peugeot & Citroen Hata Kodları
    Gönderim Zamanı: 07 Eylül 2010 Saat 17:21
P1XXX - Miscellaneous
P1000    EDC15C2 - CAN communication. Automatic gearbox
P1003    EDC15C2 - External intervention on the flow. Automatic gearbox function information; value received incorrect
P1012    EDC16C3 - Particle emission filter (PEF). Maximum number of aborted regenerations reached.
P11XX - Fuel and Air Metering
P1100    MAF (Mass Air Flow) sensor intermittent / Systems check not complete
P1101    MAF (Mass Air Flow) sensor Out of self test range
P1102    MAF (Mass Air Flow) sensor in range but lower than expected
P1103    MAF (Mass Air Flow) sensor in range but higher than expected
P1104    MAF (Mass Air Flow) ground malfunction
P1105    Dual alternator upper fault
P1106    Dual alternator lower fault / MAP (Manifold Absolute Pressure) sensor circuit Intermittent high voltage
P1107    Dual alternator lower circuit malfunction / MAP (Manifold Absolute Pressure) sensor circuit Intermittent low voltage (EDC15C2-Swirl solenoid valve)
P1108    Dual alternator battery lamp circuit malfunction / Baro to MAP (Manifold Absolute Pressure) sensor comparison too high.
    EDC15C2 - Fan high speed circuit. Open circuit or short circuit to earth.
P1109    Intake air temperature (IAT) B sensor intermittent
P1110    Intake air temperature (IAT) sensor (D/C) open/short.
    S2000 - Adaptation of the quantity of air entering the manifold.
    EDC15C2 - Airconditioning cut-off circuit. Open circuit or short circuit to earth.
P1111    Intake air temperature (IAT) sensor circuit Intermittent high voltage
P1112    Intake air temperature (IAT) sensor circuit Intermittent low voltage
    EDC15C2 - Diesel high pressure monitoring function. Pressure lower than the minimum pressure. (leak).
    MM4MP2 - Motorised throttle control.
P1113    Intake air temperature (IAT) sensor circuit open/short
    EDC16C3 - Diesel high pressure regulation circuit. Rail pressure below minimum pressure.
P1114    Engine coolant temperature (ECT) sensor circuit Intermittent low voltage / IAT - B sensor circuit low input
P1115    Engine coolant temperature (ECT) sensor circuit Intermittent high voltage / IAT - B sensor circuit high input
P1116    Engine coolant temperature (ECT) sensor out of range
P1117    Engine coolant temperature (ECT) sensor circuit Intermittent
P1118    Manifold absolute temperature sensor circuit Low input
P1119    Manifold absolute temperature sensor circuit High input
P1120    Throttle position sensor (TPS) out of range
P1121    Throttle position sensor (TPS) circuit Intermittent high voltage
P1122    Throttle position sensor (TPS) circuit Intermittent low voltage
P1123    Throttle position sensor (TPS) In range but higher than expected
P1124    Throttle position sensor (TPS) Out of self test range
P1125    Throttle position sensor (TPS) circuit Intermittent
P1126    Throttle position sensor (TPS) circuit (Narrow range) Malfunction
P1127    Exhaust not warm Downstream oxygen sensor
P1128    Upstream heated oxygen sensor (HO2S) Swapped
P1129    Downstream heated oxygen sensor (HO2S) Swapped
P1130    Lack of HO2S switching - Adaptive fuel at limit
P1131    Lack of HO2S switching - Sensor indicates lean
P1132    Lack of HO2S switching - Sensor indicated rich / EDC15C2-Catalytic convertor temperatures
P1133    HO2S 1 Insufficient switching
P1134    HO2S 1 Transition time ratio
P1135    Pedal position sensor circuit A Intermittent
    EDC15C2 - 3rd piston deactivation. Short circuit to earth or open circuit.
    Toyota 2.0 VVTi - Malfunction of the heater circuit, bank 1 upstream O2 sensor.
P1136    Fan control circuit Malfunction
P1137    Lack of HO2S 2 switching - Sensor indicates lean
P1138    High pressure rail sensor fault / Lack of HO2S 2 switching - Sensor indicates rich
    EDC15C2 - Fuel pressure. Stop requested but regulator still active.
P1139    Water in fuel indicator circuit Malfunction
P1140    Water in fuel condition
P1141    Fuel restriction indicator circuit Malfunction
P1142    Fuel restriction Condition
P1143    Air assist control valve Range / Performance
P1144    Air assist control valve circuit Malfunction
P1145    Lucas DCN2 - Noise on the needle lift sensor. Incoherence
P1150    Lack of HO2S 21 switching - Adaptive fuel at limit
    MM4MP2 - Throttle position captor, check. Coherence.
P1151    Lack of HO2S 21 switching - Sensor indicates lean
P1152    Lack of HO2S 21 switching - Sensor indicated rich
P1153    Bank 2 Fuel control shifted lean.
    MM6LP - Throttle stop learning. Malfunction
    ME744 - Motorised butterfly
P1154    Bank 2 Fuel control shifted rich
P1155    Alternative fuel controller
P1156    Fuel select switch malfunction
P1157    Lack of HO2S 22 switching - Sensor indicates lean
P1158    Lack of HO2S 22 switching - Sensor indicates rich
P1159    Fuel stepper motor Malfunction
P1161    S2000PM1 - Throttle position copy.
P1162    SIRIUS 81 - Exhaust gas recirculation. Coherence.
P1164    Fuel pressure sensor test
    SID 801 - Fuel pressure signal.
P1165    SID 803 - Fuel Pressure signal. Pressure change coherence.
P1167    Invalid test throttle not pressed
    AL4 - Fault in pressure regulation - variation/recommendation.
P1168    Fuel rail sensor In range low failure
P1169    Fuel rail sensor In range high failure / EDC15C2-Condenser 1 voltage
P1170    Engine shut off (ESO) solenoid Fault / EDC15C2-Condenser 2 voltage
P1171    Rotor sensor Fault / EDC15C2-Engine stop test by injector cut-off
P1172    Rotor control Fault
P1173    Rotor calibration Fault
P1174    Cam sensor Fault
P1175    Cam control Fault
P1176    Cam calibration Fault
    SID802 - Fuel flow regulation fault. Coherence.
P1177    Synchronisation Fault
    SID802 - Fuel flow regulation fault. Short circuit to ground.
P1178    (open)
P1179    SID802 - Fuel flow regulation fault. Short circuit between 2 wires.
P1180    Fuel delivery system Malfunction - low
    SID802 - Fuel flow regulation fault. Open circuit or short to positive.
P1181    Fuel delivery system Malfunction - high
P1182    Fuel shut off solenoid Malfunction
P1183    Engine oil temperature circuit Malfunction
P1184    Engine oil temperature Out of self test range
P1185    Fuel pump temperature sensor (FTS) high
P1186    Fuel pump temperature sensor (FTS) low
P1187    Varient selection
P1188    Calibration memory fault
P1189    Pump speed signal Fault
P1190    Calibration resistor out of range
P1191    Key line voltage
P1192    Voltage external
P1193    EGR drive Overcurrent
P1194    ECU A/D converter
P1195    SCP HBCC Failed to Inititialise
P1196    Key off voltage high
P1197    Key off voltage low / Piezo-electric injector, power stage
P1198    Pump rotor control Underfuelling
    SID801 - Diesel high pressure monitoring. Flow regulator (VCV) at stop.
P1199    Fuel level Input circuit low
P12XX - Fuel and Air Metering
P1200    Injector control circuit
    EDC16C3 Diesel high pressure monitoring. Maximum pressure exceeded.
P1201    Injector circuit open/shorted - cylinder #1
P1202    Injector circuit open/shorted - cylinder #2
P1203    Injector circuit open/shorted - cylinder #3
P1204    Injector circuit open/shorted - cylinder #4
P1205    Injector circuit open/shorted - cylinder #5
P1206    Injector circuit open/shorted - cylinder #6
P1209    Injector control pressure system Fault
P1210    Injector control pressure above expected level
P1211    Injector control pressure sensor above/below desired
P1212    Injector control pressure Not detected during crank
P1213    Start injector circuit Malfunction
P1214    Pedal position sensor B circuit Intermittent
P1215    Pedal position sensor C circuit low input
P1216    Pedal position sensor C circuit high input
P1217    Pedal position sensor C circuit Intermittent
P1218    CID high
P1219    CID low
P1220    Series throttle control system Malfunction
P1221    Traction control system Malfunction
P1222    Traction control output circuit Malfunction
P1223    Pedal demand sensor B circuit high input
P1224    Throttle position sensor B out of self test range
P1225    Needle lift sensor Malfunction
P1226    Control sleeve sensor Malfunction
P1227    Wastegate failed closed (over pressure)
P1228    Wastegate failed open (under pressure)
P1229    Intercooler pump driver Fault
P1230    Fuel pump low speed Malfunction
P1231    Fuel pump secondary circuit low high speed
P1232    Fuel pump primary speed circuit Malfunction
P1233    Fuel pump driver module Off line
P1234    Fuel pump driver module Off line
P1235    Fuel pump control Out of range
P1236    Fuel pump control Out of range
P1237    Fuel pump secondary circuit Malfunction
P1238    Fuel pump secondary circuit Malfunction
P1239    Speed fuel pump position feed Fault
P1240    Sensor power supply Malfunction
P1241    Sensor power supply Low input
P1242    Sensor power supply High input
P1243    Second fuel pump faulty or ground fault
P1244    Alternator load input failed High
P1245    Alternator load input failed Low
P1246    Alternator load input failed
P1247    Turbo boost pressure Low
P1248    Turbo boost pressure not detected
P1249    Wastegate control valve performance
P1250    PRC solenoid circuit Malfunction
P1251    Air mixture solenoid circuit Malfunction
P1252    Pedal correlation PDS1 & LPDS High
P1253    Pedal correlation PDS1 & LPDS Low
P1254    Pedal correlation PDS2 & LPDS High
P1255    Pedal correlation PDS2 & LPDS Low
P1256    Pedal correlation PDS1 & HPDS
P1257    Pedal correlation PDS2 & HPDS
P1258    Pedal correlation PDS1 & PDS2
P1259    Immobiliser to PCM signal error
P1260    Theft detected Vehicle immobilised
P1261    Cylinder #1 High to Low short
P1262    Cylinder #2 High to Low short
P1263    Cylinder #3 High to Low short
P1264    Cylinder #4 High to Low short
P1265    Cylinder #5 High to Low short
P1266    Cylinder #6 High to Low short
P1267    Cylinder #7 High to Low short
P1268    Cylinder #8 High to Low short
P1269    Immobiliser Code not programmed
P1270    Engine RPM or speed limiter reached
P1271    Cylinder #1 High to Low open
P1272    Cylinder #2 High to Low open
P1273    Cylinder #3 High to Low open
P1274    Cylinder #4 High to Low open
P1275    Cylinder #5 High to Low open
P1276    Cylinder #6 High to Low open
P1277    Cylinder #7 High to Low open
P1278    Cylinder #8 High to Low open
P1280    Injection control pressure Out of range Low
P1281    Injection control pressure Out of range High
P1282    Excessive injection control pressure
P1283    IPR circuit failure
P1284    Aborted KOER - ICP failure
P1285    Cylinder head over temp sensed
P1286    Fuel pulse In range but Lower than expected
P1287    Fuel pulse In range but Higher than expected
P1288    Cylinder head temp sensor Out of self test range
    SIRIUS81 (EW10D) - Fuel rail pressure. Low value received.1
P1289    Cylinder head temp sensor High input
    EW10J4S - Dual inlet. Activation of second air intake duct. Circuit malfunction
P1290    Cylinder head temp sensor Low input
    EW10J4S - Dual inlet. Activation of second air intake duct. Performance field
P1291    Injector High side short to GND or VBATT - Bank 1
    SIRIUS81 (EW10D)- Fuel pressure regulation fault. Output/Locking.
    Fuel rail pressure. Low value received.2
P1292    Injector High side short to GND or VBATT - Bank 2
    EW10J4S - Dual inlet. Activation of second air intake duct. Circuit, lower malfunction
P1293    Injector High side open - Bank 1
    EW10J4S - Dual inlet. Activation of second air intake duct. Circuit, upper malfunction
P1294    Injector High side open - Bank 2/Target idle not reached
    SIRIUS81 (EW10D) - Fuel rail pressure. High value received.1
P1295    Multi-faults - Bank 1 - with low side shorts
    EW10J4S - Dual inlet. Activation of second air intake duct. Intermittent circuit
P1296    Multi-faults - Bank 2 - with low side shorts
    Additive injector. Open circuit
P1297    Injector high sides shorted together
    SIRIUS81 (EW10D) - Fuel rail pressure. High value received.2
P1298    IDM failure
    Additive injector. Circuit, upper breakdown
P1299    Cylinder head overtemperature protection active
    Additive injector. Circuit, lower breakdown
P13XX - Ignition system
P1300    Boost calibration fault
P1301    Boost calibration High
P1302    Boost calibration Low
P1303    EGR calibration fault
P1304    EGR calibration High
P1305    EGR calibration Low
P1306    Kickdown Relay pull - In circuit fault
P1307    Kickdown Relay Hold circuit fault
P1308    A/C clutch circuit fault
P1309    Misfire monitor AICE chip fault
P1313    Misfire rate Caltalyst damage fault - Bank 1
P1314    Misfire rate Catalyst damage fault - Bank 2
P1315    Persistent misfire
P1316    Injector circuit IDM codes detected
P1317    Injector circuit IDM codes not detected
P1327    S2000P - Ignition - Integrated Phase detection
P1336    Crank/Cam sensor range/performance
    S2000PM1/2 - High misfire on several cylinders
    ME7.4.5. Combustion misfiring on unspecified cylinders.
P1338    ME7.4.5. Cylinder No.2 misfires.
P1340    Camshaft position sensor B circuit Malfunction
P1341    Camshaft position sensor B range/performance
P1345    SGC (cam position) sensor circuit Malfunction / Crankshaft
P1346    Fuel level sensor B circuit Malfunction
P1347    Fuel level sensor B range / performance
P1348    Fuel level sensor B circuit Low
P1349    Fuel level sensor B circuit High
P1350    Fuel level sensor B Intermittent/Bypass line monitor
    SID 801 - Pre/Post heating relay circuit - Short or Open circuit, including Pre-Heat plugs
    EDC16C34 - Preheating relay circuit control in short circit to earth or open circuit. (Check battery status).
P1351    IDM input circuit Malfunction/Ignition coil control circuit High voltage
    SID 803/EDC16C3 - Pre/Post heating relay circuit. Relay not controlled and glow plugs supplied.
P1352    Ignition coil A Primary circuit Malfunction / SID 801- Pre/Post heating relay circuit - Relay & Pre-Heat plugs not controlled
P1353    Ignition coil B Primary circuit Malfunction
P1354    Ignition coil C Primary circuit Malfunction
P1355    Ignition coil D Primary circuit Malfunction
P1360    Ignition coil A Secondary circuit Malfunction
P1361    Ignition control (IC) circuit Low voltage
P1362    Ignition coil C Secondary circuit Malfunction
P1363    Ignition coil D Secondary circuit Malfunction
P1364    Ignition coil Primary circuit Failure
P1365    Ignition coil Secondary circuit Failure
P1366    Ignition spare
P1367    Ignition spare
P1368    Ignition spare
P1369    Engine temperature light monitor Malfunction
P1370    Insufficient RMP increase during spark test
P1371    Ignition coil - Cylinder #1 - Early activation fault
P1372    Ignition coil - Cylinder #2 - Early activation fault
P1373    Ignition coil - Cylinder #3 - Early activation fault
P1374    Crankshaft position (CKP) / Ignition coil - Cylinder #4 - Early activation fault
P1375    Ignition coil - Cylinder #5 - Early activation fault
P1376    Ignition coil - Cylinder #6 - Early activation fault
P1380    Misfire detected - Rough road date not available
P1381    Variable Cam timing Overadvanced (Bank #1) / Misfire detected no communiction with BCM
P1382    Variable Cam timing solenoid #1 circuit Malfunction
P1383    Variable Cam timing Overretarded (Bank #1)
P1384    VVT solenoid A Malfunction
P1385    Variable Cam timing solenoid B Malfunction
P1386    Variable Cam timing Overadvanced (Bank #2)
P1387    Variable Cam timing solenoid #2 circuit Malfunction
P1388    Variable Cam timing Overretarded (Bank #2)
P1389    Glow plug circuit High side Low input
P1390    Octane adjust pin out of self test range
P1391    Glow plug circuit Low input (Bank #1)
P1392    Glow plug circuit High input (Bank #1)
P1393    Glow plug circuit Low input (Bank #2)
P1394    Glow plug circuit High input (Bank #2)
P1395    Glow plug monitor Fault (Bank #1)
P1396    Glow plug monitor Fault (Bank #2)
P1397    System voltage Out of selt test range
P1398    VVT solenoid B circuit High input
P1399    Glow plug circuit High side High input
P14XX - Auxiliary Emission Controls
P1400    DPFE circuit Low input
P1401    DPFE circuit High input
P1402    EGR metering Orifice restricted
    Lucas DCN2 - EGR butterfly solenoid valve control. Short circuit to earth or short circuit to positive or open circuit.
    EDC15C2 - EGR: Throttle electrovalve. Short circuit to earth or open circuit.
P1403    Additional heating circuit 1
    EDC16C3 - Additional heating circuit 1. Short circuit to earth, short circuit to positive, open circuit or actuator.
P1404    IAT - B circuit Malfunction / EGR closed position performance
    EDC15C2 - Additional heating circuit 2 and pre-heat
    EDC16C3 - Additional heating circuit 2. Short circuit to earth, short circuit to positive, open circuit or actuator.
P1405    DPFE sensor upstream Hose off or plugged
P1406    EGR position sensor performance
P1407    EGR No flow detected
P1408    EGR Flow out of selt test range
    EDC15C2-Additional heating circuit
P1409    EVR control circuit Malfunction
P1411    SAI system incorrect downstream flow detected
    EDC15C2-Converter upstream temperature
P1413    SAI system monitor circuit Low input
P1414    SAI system monitor circuit High input
P1415    Air pump circuit Malfunction / Air system bank 1
P1416    Port air circuit Malfunction / Air system bank 2
    EDC15C2-Converter downstream temperature
P1417    Port air relief circuit Malfunction
P1418    Split air #1 circuit malfunction
P1419    Split air #2 circuit malfunction
P1420    Catalyst temperature sensor failure
P1421    Catalyst damaged
P1422    EGI temperature sensor failure
P1423    EGI functionality test failed
P1424    EGI Glow plug Primary failure
P1425    EGI glow plug Secondary failure
    ED15C2 with FAP - Catalytic converter downstream temperature signal. Short circuit to positive or open circuit or Coherence between converter 1 & 2 temperature signal.
P1426    EGI mini MAF failed Out of range
P1427    EGI mini MAF failed Short circuit
P1428    EGI mini MAF failed Open circuit
P1429    Electric air pump Primary failure
    EDC15C2 Particulate Differential pressure sensor value. Coherence of the differential pressure when stopped.
P1430    Electric air pump Secondary failure
P1433    A/C Refrigerant temperature circuit Low
P1434    A/C Refrigerant temperature circuit High
P1435    A/C Refrigerant temperature circuit Range/Performance.
    EDC15C2 - Additive adding system. Faults additive accuracy.
    EDC15C2 - Additive system. Fuel gauge fault.
    EDC15C2 - Additive system. Low additive level sensor fault.
    EDC15C2 - Additive system. Fuel filler cap present sensor fault.
    EDC15C2 - Additive system. Faults additive pump.
    EDC16C3 - Additive system. Value received by the CAN network incorrect.
P1436    A/C Evaporator air temperature circuit Low
P1437    A/C Evaporator air temperature circuit High
P1438    A/C Evaporator air temperature circuit Range/Performance
P1439    Floor temperature switch circuit malfunction
P1440    Purge valve stuck open
P1441    Evaporative emission (EVAP) system flow during non-purge (Oldsmobile / Chevrolet only)
P1442    Evaporative emission control system Leak detected
    EDC15C2-Quantity of additive Additive ECU.
P1443    Evaporative emission control system control valve
P1444    Purge flow sensor circuit Low input
P1445    Purge flow sensor circuit High input
    EDC16C3 - Additive system. Quantity of additive too high.
P1446    Evaporative vac solenoid circuit malfunction
    EDC15C2-(607) Additive level.
    EDC15C2-(307/406) Additive quantity. Additive minimum level wait.
P1447    ELC system closure valve Flow fault
    EDC15C2 - PEF filter pierced or differential pressure incorrect. / PEF: Particle emission filter. Clogged particle filter.
P1448    ELC system 2 fault
    EDC15C2 PEF: Particulate emission filter overloaded.
P1449    Evaporative check solenoid circuit malfunction
P1450    Unable to bleed up fuel tank vacuum
P1451    Evaporative emission control system vent control valve circuit
P1452    Unable to bleed Up vacuum in tank
P1453    Fuel tank pressure relief valve malfunction
P1454    Evaporative system vacuum test malfunction
P1455    Evaporative emission control system Leak detected (Gross leak / no flow)
P1456    Fuel tank temperature sensor circuit malfunction
P1457    Unable to pull vacuum in tank
P1458    Coolant solenoid valve Short to earth or open circuit.
P1460    Wide open throttle A/C cutoff relay circuit
P1461    A/C pressure sensor circuit Voltage Low
    SID 803 - EGR valve. Learning
P1462    A/C pressure sensor circuit Voltage High
P1463    A/C pressure sensor Insufficient pressure change
P1464    A/C demand Out of self test range
P1465    A/C Relay circuit malfunction
P1466    A/C Refrigerant temperature sensor /circuit malfunction
P1467    A/C Compressor temperature sensor malfunction
P1468    SSPOD Open circuit or Closed circuit fault
P1469    Low A/C cycling period
P1470    A/C Cycling period too short
P1471    Electrodrive Fan 1 Operational failure (Driver side)
    EDC16C3 / SID802-804 - RAS actuator. Operating field / performance.
P1472    Electrodrive Fan 2 Operational failure (Passenger side)
P1473    Fan Secondary High with fans (off)
P1474    Low fan control Primary circuit malfunction
P1475    Fan relay (low) circuit malfunction
P1476    Fan relay (high) circuit malfunction
P1477    Additional fan relay circuit malfunction
    EDC15C2-Coolant solenoid valve
P1478    Cooling fan driver fault
P1479    High fan control Primary circuit malfunction
P1480    Fan secondary low with low fan on
P1481    Fan secondary low with high fan on
P1482    SCP
P1483    Power to fan circuit Overcurrent
P1484    Open power to ground VCRM
P1485    EGRV circuit malfunction
P1486    EGRA circuit malfunction
P1487    EGRCHK solenoid circuit malfunction
P1490    Secondary Air relief solenoid circuit malfunction
P1491    Secondary switch solenoid circuit malfunction
P1492    APLSOL solenoid circuit malfunction
P1493    RCNT solenoid circuit malfunction
P1494    SPCUT solenoid circuit malfunction
P1495    TCSPL solenoid circuit malfunction
P15XX - Vehicle speed / Idle control and Auxiliary Inputs
P1500    Vehicle speed sensor Intermittent
P1501    Vehicle speed sensor Out of self test range
P1502    Vehicle speed sensor Intermittent malfunction
P1503    Auxiliary speed sensor fault
P1504    Idle air control circuit malfunction
P1505    Idle air control system at adaptive clip
    EDC16C3 - Impact detection. Impact information sent by the air bag.
P1506    Idle air control Overspeed error
P1507    Idle air control Underspeed error
    EDC15C2-Anti-boiling strategy activated
P1508    Idle control system circuit Open
P1509    Idle control system circuit Shorted
P1510    Idle signal circuit malfunction
P1511    Idle switch (Electronic control Throttle) circuit malfunction
    EDC15C2-ECU supplied as +APC
P1512    Intake manifold runner control (Bank 1) Stuck closed
P1513    Intake manifold runner control (Bank 2) Stuck closed
P1514    High load Neutral/Drive fault
P1515    Electric current circuit malfunction
P1516    IMRC Input error (Bank 1)
P1517    IMRC Input error (Bank 2)
    EDC15C2-Coded anti-start function
P1518    Intake manifold runner control (Stuck open)
    ME7.4.4 - Stop lamp information.
P1519    Intake manifold runner control (Stuck closed)
P1520    Intake manifold runner control circuit malfunction
P1521    Variable intake solenoid #1 circuit malfunction
    EDC15C2-Clutch sensor
P1522    Variable intake solenoid #2 circuit malfunction
P1523    IVC solenoid circuit malfunction
P1524    Variable intake solenoid system
P1525    Air bypass valve system
    MM4.8P - Idle regulation stepper motor. Short circuit to positive or short circuit to earth.
P1526    Air bypass system
P1527    Accelerate warmup solenoid circuit malfunction
    EDC16C34 - Alternator charge. Information alternator charge signal lower than minimum limit.(Battery voltage).
P1528    Subsidiary Throttle valve solenoid malfunction
P1529    SCAIR solenoid circuit malfunction
P1530    A/C clutch circuit malfunction
P1531    Invalid test - Accelerator pedal movement
P1532    IMCC circuit malfunction Bank B
P1533    AAI circuit malfunction
P1534    Inetia switch activated
P1535    Blower fan speed circuit range/performance
P1536    Parking brake switch circuit failure
    EDC15C2-ESP plausibility
    ME745 - Check brake light switch
    EDC16C34 - Brake switch signal inconsistency between 2 brale pedal signals.
P1537    Intake manifold runner control (Bank 1) Stuck open
    EDC15C2 - Accelerator pedal jammed. Strategy activated.
P1538    Intake manifold runner control (Bank 2) Stuck open
P1539    Power to A/C clutch circuit Overcurrent
P1540    Air bypass valve circuit malfunction
P1543    Air conditioning compressor cut-off circuit
P1549    IMCC circuit malfunction Bank B
P1550    PSPS Out of self test range
P1565    Speed control command switch Out of range High
P1566    Speed control command switch Out of range Low
P1567    Speed control Output circuit continuity
P1568    Speed control Unable to hold speed
P1571    Brake switch malfunction
P1572    Brake pedal switch circuit malfunction
P1573    Throttle position Not available
P1574    Throttle position sensor Disagreement between sensors
P1575    Pedal position Out of self test range
P1576    Pedal position Not available
P1577    Pedal position sensor Disagreement between sensors
P1578    ETC Power less than demand
P1579    ETC In power limiting mode
P1580    Electronic throttle monitor PCM Override
P1581    Electronic throttle monitor malfunction
P1582    Electronic throttle monitor Data available
P1583    Electronic throttle monitor Cruise disable
P1584    TCU detected IPE circuit malfunction
P1585    Throttle control unit malfunction
P1586    Throttle control unit Throttle position malfunction
P1587    Throttle control unit modulated command malfunction
P1588    Throttle control unit detected loss of return spring
P1589    TCU Unable to control desired throttle angle
P16XX - Computer and Auxiliary Outputs
P1600    Loss of Keep alive memory(KAM) power Open circuit
P1601    ECM/TCM Serial communication error
P1602    Immobiliser/ECM communication error
P1603    EEPROM malfunction
P1604    Code word Unregistered
P1605    Keep alive memory (KAM) test failure
    Lucas DCN2 Driver's requirement. Short circuit to positive or short circuit to earth
P1606    ECM control relay O/P circuit malfunction
P1607    MIL O/P circuit malfunction
    MM6LP - Speed limiter.
P1608    Internal ECM malfunction (Bosch system-Control.Coolant temperature alert)
P1609    Diagnostic lamp driver fault
P1610    SBDS Interactive codes
P1611    SBDS Interactive codes
P1612    SBDS Interactive codes
P1613    Configuration
P1614    SBDS Interactive codes
P1615    SBDS Interactive codes
P1616    SBDS Interactive codes
P1617    SBDS Interactive codes
P1618    SBDS Interactive codes
P1619    SBDS Interactive codes
P1620    SBDS Interactive codes
P1621    Control module Long term memory performance / Immobiliser code words Not matched
    MM6LP - System anomaly. Safety.
P1622    Immobiliser ID does not match / System anomaly
P1623    Immobiliser code word / ID number Write failure
P1624    Anti theft system
P1625    B+ supply to VCRM fan circuit malfunction
P1626    Theft deterent fuel enable signal not received / B+ supply to VCRM A/C circuit malfunction
P1627    Module supply voltage Out of range
P1628    Module Ignition supply Input malfunction
P1629    Internal voltage regulator malfunction
P1630    Internal Vref malfunction
P1631    Theft deterent Start enable signal not correct/Main relay malfunction (Power latch)/ Internal ECM fault / Configuration fault)
P1632    Smart alternator faults sensor/circuit malfunction
P1633    KAM voltage too low
P1634    Data Output link circuit failure
    SIRIUS81 - Ignition on ECU supply control. Short circuit to positive
P1635    Tyre / Axle ratio Out of acceptable range
P1636    Inductive signiture Chip communication error
P1637    CAN link ECM?ABSCM circuit / network malfunction
P1638    CAN link ECM/INSTM circuit / network malfunction
P1639    Vehicle ID block corrupted or not programmed
P1640    Powertrain DTCs available in another module
P1641    Fuel pump Primary circuit failure
    SID801 Piezo-electric injector, power stage.
P1642    Fuel pump monitor circuit High input
P1643    Fuel pump monitor circuit Low input
P1644    Fuel pump speed control circuit malfunction
P1645    Fuel pump resistor switch circuit malfunction
P1650    PSP switch Out of self test range
P1651    PSP switch Input malfunction
P1652    IAC monitor disabled by PSP switch failed on
P1653    Power steering Output circuit malfunction
P1654    Recirculation Override circuit malfunction
P1655    Starter disable circuit malfunction
P1660    Output circuit check signal High
P1661    Output circuit check signal Low
P1662    IDM_EN circuit failure
P1663    Fuel demand command signal circuit malfunction
P1667    CI circuit malfunction
P1668    PCM-IDM communications error
P1670    Electronic feedback signal Not detected
P1671    MM6LP - Cruise control.
P1680    Metering Oil pump malfunction
P1681    Metering Oil pump malfunction
P1682    Metering Oil pump malfunction
P1683    Metering Oil pump temperature sensor circuit malfunction
P1684    Metering Oil pump position sensor circuit malfunction
P1685    Metering Oil pump stepping motor circuit malfunction
P1686    Metering Oil pump stepping motor circuit malfunction
P1687    Metering Oil pump stepping motor circuit malfunction
    Lucas DCN2 (DW8B) - Pump module not matched
P1688    Metering Oil pump stepping motor circuit malfunction
P1689    Oil pressure control solenoid circuit malfunction
P1690    Wastegate solenoid circuit malfunction
P1691    Turbo pressure control solenoid circuit malfunction
P1692    Turbo control solenoid circuit malfunction
P1693    Turbo charge control circuit malfunction
    SID 803 Starting and switching off of the engine controlled. Starting or switch-off requests absent or not valid.
    J34P - Remote control wake-up inconsistency problem.
P1694    Turbo charge relief circuit malfunction
P17XX - Transmission
P1700    Transmission Indeterminate failure (failed to neutral)
P1701    Reverse engagement error
P1702    TRS circuit Intermittent malfunction
P1703    Brake switch Out of self test range
P1704    Digital TRS failed to transmission states in KOEO / KOER
P1705    Not in P or N during KOEO / KOER
P1706    High vehicle speed observed in Park
P1707    Transfer cas Neutral indicator Hard fault present
P1708    Clutch switch circuit malfunction
P1709    PNP switch Out of self test range
P1711    TFT sensor Out of self test range
P1712    Transmission Torque reduction request signal malfunction
P1713    TFT sensor In range failure Low value
P1714    SSA Inductive signiture malfunction
P1715    SSB Inductive signiture malfunction
P1716    SSC Inductive signiture malfunction
P1717    SSD Inductive signiture malfunction
P1718    TFT sensor In range failure High
    BVMPMA (sensodrive gearbox)- Gear selctor signal coherence.
P1720    Vehicle speed (meter) circuit malfunction
P1721    Gear 1 Incorrect ratio
P1722    Gear 2 Incorrect ratio
P1723    Gear 3 Incorrect ratio
    AL4 - Gearbox output engine speed signal fault. No signal.
P1724    Gear 4 Incorrect ratio
P1725    Insufficient engine speed increase during self test
P1726    Insufficient engine speed decrease during self test
P1727    Coast clutch solenoid Inductive signiture malfunction
P1728    Transmission slip error
    EDC16C3 - Multiplexing. No communication with the automatic gearbox.
P1729    4x4 Low switch error
P1730    Gear control malfunction 2,3,5
P1731    1-2 Shift malfunction
P1732    2-3 Shift malfunction
P1733    3-4 Shift malfunction
P1734    Gear control malfunction
P1735    First gear switch circuit malfunction
P1736    Second gear switch circuit malfunction
P1737    Lockup solenoid system
P1738    Shift time error
P1739    Slip solenoid system
P1740    Torque converter clutch Inductive signiture malfunction
P1741    Torque converter clutch control error
P1742    Torque converter clutch solenoid failed On
P1743    Torque converter clutch solenoid failed On
P1744    Torque converter clutch system performance
P1745    Line pressure solenoid system
P1746    Pressure control solenoid A Open circuit
P1747    Pressure control solenoid A Short circuit
P1748    EPC malfunction
    AL4 - Exchanger management solenoid valve output fault. Open circuit.
P1749    Pressure control solenoid failed Low
P1751    Shift solenoid A performance
P1754    Coast clutch solenoid circuit malfunction
P1755    Intermediate speed sensor (ISS) malfunction
P1756    Shift solenoid B performance
P1760    Pressure control solenoid A Short circuit
P1761    Shift solenoid C performance
P1762    Overdrive band failed Off
P1765    Timing solenoid circuit malfunction
P1767    Torque converter clutch circuit malfunction
P1768    Performance / Normal / Winter mode Input malfunction
P1769    AG4 Transmission torque modulation fault
P1770    Clutch solenoid circuit malfunction
P1775    Transmission system MIL fault
P1776    Ignition retard request duration fault
P1777    Ignition retard request circuit fault
P1778    Transmission reverse I/P circuit malfunction
P1779    RCIL circuit malfunction
P1780    Transmission control switch (O/D cancel) Out of self test range
P1781    4x4 switch Out of self test range
P1782    P/ES circuit Out of self test range
P1783    Transmission Overtemperature condition
P1784    Transmission mechanical failure-First and Reverse
P1785    Transmission mechanical failure-First and Second
P1786    3-2 Downshift error
P1787    2-1 Downshift error
P1788    Pressure control solenoid B Open circuit
P1789    Pressure control solenoid B Short circuit
P1790    TP (mechanical) circuit failure
P1791    TP (electric) circuit failure
P1792    Barometer pressure circuit malfunction
P1793    Intake air volume circuit malfunction
P1794    Battery voltage circuit malfunction
P1795    Idle switch circuit malfunction
P1796    Kickdown switch circuit malfunction
P1797    Neutral switch circuit malfunction
P1798    Coolant temperature circuit malfunction
P1799    Hold switch circuit malfunction
P18XX - Transmission
P1800    Transmission clutch Interlock safety switch circuit failure
P1801    Transmission clutch Interlock safety switch Open circuit
P1802    Transmission clutch Interlock safety switch short circuit to Battery
P1803    Transmission clutch Interlock safety switch short circuit to ground
P1804    Transmission 4-wheel drive High indicator circuit failure
P1805    Transmission 4-wheel drive High indicator Open circuit
P1806    Transmission 4-wheel drive High indicator short circuit to battery
P1807    Transmission 4-wheel drive High indicator short circuit to ground
P1808    Transmission 4-wheel drive Low indicator circuit failure
P1809    Transmission 4-wheel drive Low indicator Open circuit
P1810    TFP valve position switch circuit / transmission 4-wheel drive Low indicator short circuit to battery
P1811    Transmission 4-wheel drive Low indicator Short to ground
P1812    Transmission 4-wheel drive mode select circuit failure
P1813    Transmission 4-wheel drive mode select Open circuit
P1814    Transmission 4-wheel drive mode select short to battery
P1815    Transmission 4-wheel drive mode select short to ground
P1816    Transmission Neutral safety switch circuit failure
P1817    Transmission Neutral safety switch Open circuit
P1818    Transmission Neutral safety switch Short circuit to battery
P1819    Transmission Neutral safety switch Short circuit to ground
P1820    Transmission transfer case clockwise shift relay coil circuit failure
P1821    Transmission transfer case clockwise shift relay coil Open circuit
P1822    Transmission transfer case clockwise shift relay coil Short circuit to battery
P1823    Transmission transfer case clockwise shift relay coil Short circuit to ground
P1824    Transmission 4-wheel drive clutch relay circuit failure
P1825    Transmission 4-wheel drive clutch relay Open circuit
P1826    Transmission 4-wheel Low clutch relay circuit to battery
P1827    Transmission 4-wheel Low clutch relay circuit to ground
P1828    Transmission transfer case counter clockwise shift relay coil circuit failure
P1829    Transmission transfer case counter clockwise shift relay coil Open circuit
P1830    Transmission transfer case counter clockwise shift relay coil short circuit to battery
P1831    Transmission transfer case counter clockwise shift relay coil short circuit to ground
P1832    Transmission transfer case differetial lockup solenoid circuit failure
P1833    Transmission transfer case differetial lockup solenoid Open circuit
P1834    Transmission transfer case differetial lockup solenoid short circuit to battery
P1835    Transmission transfer case differetial lockup solenoid short circuit to ground
P1836    Transmission transfer case front shaft speed sensor circuit failure
P1837    Transmission transfer case rear shaft speed sensor circuit failure
P1838    Transmission transfer case shift motor circuit failure
P1839    Transmission transfer case shift motor Open circuit
P1840    Transmission transfer case shift motor short circuit to battery
P1841    Transmission transfer case shift motor short circuit to ground
P1842    Transmision transfer case differential lockup feedback switch circuit failure
P1843    Transmision transfer case differential lockup feedback switch Open circuit
P1844    Transmision transfer case differential lockup feedback switch short circuit to battery
P1845    Transmision transfer case differential lockup feedback switch short circuit to ground
P1846    Transmission transfer case contact plate A circuit failure
P1847    Transmission transfer case contact plate A Open circuit
P1848    Transmission transfer case contact plate A Short circuit to battery
P1849    Transmission transfer case contact plate A short circuit to ground
P1850    Transmission transfer case contact plate B circuit failure
P1851    Transmission transfer case contact plate B Open circuit
P1852    Transmission transfer case contact plate B Short circuit to battery
P1853    Transmission transfer case contact plate B Short circuit to ground
P1854    Transmission transfer case contact plate C circuit failure
P1855    Transmission transfer case contact plate C Open circuit
P1856    Transmission transfer case contact plate C Short circuit to battery
P1857    Transmission transfer case contact plate C Short circuit to ground
P1858    Transmission transfer case contact plate D circuit failure
P1859    Transmission transfer case contact plate C Open circuit
P1860    TCC PWM solenoid circuit electrical / transmission transfer case contact plate D Short circuit to battery
P1861    Transmission transfer case contact plate D Short circuit to ground
P1862    Transmission transfer case contact plate power circuit failure
P1863    Transmission transfer case contact plate power Open circuit
P1864    Transmission transfer case contact plate power Short circuit to battery
P1865    Transmission transfer case contact plate power Short circuit to ground
P1866    Transmission transfer case system concern - Setting required
P1867    Transmission transfer case contact plate General circuit failure
P1868    Transmission automatic 4-wheel drive indicator lamp circuit failure
P1869    Transmission automatic 4-wheel drive indicator lamp circuit Short to battery
P1870    Tansmission component slipping/Transmission mechanicl transfer case 4x4 switch circuit malfunction
P1871    Transmission mechanical transfer case 4x4 switch circuit Short to battery
P1872    Transmission mechanical 4-wheel drive Axle lock lamp circuit failure
P1873    Transmission mechanical 4-wheel drive Axle lock lamp circuit Short to battery
P1874    Transmission automatic hall effect sensor power circuit failure
P1875    Transmission automatic hall effect sensor power circuit Short to battery / 4wd Low switch circuit electrical
P1876    Transmission transfer case 2-wheel drive solenoid circuit failure
P1877    Transmission transfer case 2-wheel drive solenoid circuit Short to battery
P1878    Transmission transfer case disengaged solenoid circuit failure
P1879    Transmission transfer case disengaged solenoid Open circuit
P1880    Transmission transfer case disengaged solenoid short to battery
P1881    Engine coolant level switch circuit failure GEM
P1882    Engine coolant level switch circuit Short to ground
P1883    Engine coolant level switch circuit failure GEM
P1884    Engine coolant level lamp circuit Short to ground
P1885    Transmission transfer case disengaged solenoid Short to ground
P1886    4x4 Initialisation failure
P1890    Transmission 4wd mode select return input circuit failure
P1891    Transmission transfer case contact plate ground return Open circuit
P19XX - Transmission
P1900    OSS circuit intermittent malfunction
P1901    TSS circuit intermittent malfunction
P1902    Pressure control solenoid B intermittent short
P1903    Pressure control solenoid C Short circuit
P1904    Pressure control solenoid C Open circuit
P1905    Pressure control solenoid C Intermittent short
P1906    Kickdown pull relay Open or Short circuit to ground
P1907    Kickdown hold relay Open or Short circuit to ground
P1908    Transmission pressure circuit solenoid Open or Short to ground
P1909    Transmission temperature sensor circuit Open or Short to power or ground
P1910    VFS A pressure Output failed Low
P1911    VFS B pressure Output failed Low
P1912    VFS C pressure Output failed Low
P1913    Pressure switch A circuit malfunction
P1914    Manually shifted automatic (MSA) switch circuit malfunction
P1915    Reverse switch circuit malfunction
P1916    High clutch drum speed sensor malfunction
P1917    High clutch drum speed sensor Intermittent
P1918    Transmission range display circuit malfunction
P2002    Particulate emission filter
P2021    CAN engine torque information. No signal
P2025    Engine speed signal. No signal
P2101    S2000PM1 - Motorised throttle control coherence
P2120    Intake air heating circuit
P2137    EDC16C3 - Accelerator pedal 1, signal consistency with pedal 2 signal
P2144    EGR valve
P2199    SID 803 Air temperature after exchanger signal. Coherence with the intake air temperature.
P2263    Multifunction switch signal fault. Intermediate position
P2299    Accelerator pedal blocked
P2408    EDC16C3 - Additive system. Fuel tank cap presence sensor.
P2562    SID 803.Turbo pressure solenoid valve. Valve position too distant in relation to reference value, (repeat value for turbo incorrect)
P2563    SID 803.Turbo pressure solenoid valve. Valve position too distant in relation to reference value, (repeat value for turbo incorrect)
P3004    3rd piston de-activator
Çıktığın kapıyı sert çarpma, geri dönüp açman gerekebilir. (Atasözü)
Leon 1.6 DSG / 206 XT 1.4
Çevrimdışı EminÖNAL Açılır Kutu Gör
P.T. MODERATÖR
Kayıt Tarihi: 02 Ekim 2009
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı EminÖNAL Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 07 Eylül 2010 Saat 17:25
paylaşım için teşekkürler rıfat.
bide google amcaya türkçeye çevirtseydin ya :)
A3
02 - Ağustos - 1981
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı rifatseker Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 07 Eylül 2010 Saat 17:29
Onun çevirdiği türkçeyi ben anlamakta zorluk çekiyorum. İsteyen çevirsin artık :))
Çevrimdışı BuRÇaK Açılır Kutu Gör
16 - Temmuz - 1981
Kayıt Tarihi: 17 Şubat 2010
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı BuRÇaK Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 07 Eylül 2010 Saat 20:12
yuh bu ne yaaa?bu kadar hata veren arabamı olur?  :)))
Çevrimdışı Aytaç Açılır Kutu Gör
GTI
Kayıt Tarihi: 29 Temmuz 2009
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı Aytaç Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 07 Eylül 2010 Saat 23:55
Orjinalini yazan: BuRÇaK BuRÇaK Yazdı:
Neler Neler Var Deli Eder Ustayı...))))) Güzel Paylasım İcin Tesekkur Borcluyuzz....
StOcK 99 106 S16/GTI
Çevrimdışı Qwerty1971 Açılır Kutu Gör
Aracı : Ds4
Kayıt Tarihi: 02 Ekim 2018
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı Qwerty1971 Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 02 Ekim 2018 Saat 16:23
arkadaslar bende ds4 style var.
P1aa0 diye bir hata kodu verdi.
Bunun ne oldugunu bilen varmi.
Bide start stop calismiyor.
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı sonerkyl Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 02 Ekim 2018 Saat 16:26
Orjinalini yazan: Qwerty1971 Qwerty1971 Yazdı:
öncelikle aramıza hoşgeldiniz. sorun muhtemelen akünüz zayıflamış hocam yada şarj dinmasu yeterli şarj yapmıyor. Ama genelde aküden kaynaklanır. Hata koduda bundan dolayı veriyor.
Çevrimdışı ALPER_UA Açılır Kutu Gör
Aracı : 2008
Kayıt Tarihi: 27 Aralık 2020
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı ALPER_UA Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 21 Şubat 2021 Saat 04:54
benim arabamın verdiği hata kodu niye yok burada Cry
p1067 p1047 p1015 bu kodları veriyor ve silinmiyor Araba benzinli gaz yemiyor.
ALPER SÖZER
konu icon 206 Radyatör Hava Alma İşlemi son mesaja git 449 0 Berkan123
konu icon Birden Stop Etme son mesaja git 5432 8 Berkan123
konu icon Genleşme kabında basınç son mesaja git 1102 3 Berkan123
konu icon Hararet Göstergesi son mesaja git 742 4 Berkan123
konu icon 206 Hararet Sorunu son mesaja git 604 4 Berkan123
konu icon 206 otomatik vites sorunu son mesaja git 2641 11 feyyazbugan
konu icon 206 şakırtı sesi geliyor son mesaja git 1010 4 berkogut
konu icon 1.4 HDi Emme Manifoltu Nasıl Takılır? son mesaja git 1774 4 antipollution
konu icon 307 kendi kendine gaz veriyor. son mesaja git 12627 36 drneuron
konu icon Android Auto Sorunu - Xiaomi 13T Pro son mesaja git 531 0 chanyilmz
konu icon Fikirlerinize ihtiyacım var son mesaja git 434 0 Mustafa1923
konu icon Peugeot 206 hakkında yardım son mesaja git 395 0 Mustafa1923
konu icon tahin kıvamında soğutma suyu-rektefiye son mesaja git 447 0 claymore
konu icon 206 kalorifer sıcak soguk arkadan ayarı son mesaja git 465 0 heavyburak26
konu icon 2010 3008 1.6 vti sorunlar zinciri son mesaja git 703 0 cagri_serin
konu icon Tüm arıza göstergeleri aktif son mesaja git 505 0 Volkan 00
konu icon ENG man system faulty - Hatası (Resimli) son mesaja git 15986 16 YKH
konu icon Otomatik Şanzıman Geç Vites Atma Sorunu son mesaja git 5487 10 Stcngnr28
konu icon 206 1.4 8v Subap Ayarı(Resimli) son mesaja git 1833 1 arifbsrn
konu icon Bilgi ekranı son mesaja git 463 0 Erdo
ggitaristt 1
Musta08 1
